Fuel Pump Tank Connector
Discussion in 'The Garage' started by msb350, Oct 3, 2005.
  1. msb350
    msb350 Registered Member
    Jul 6, 2004
    96
    Texas
    How do you get the electrical connection off the fuel tank???? I removed all the lines but the pumps electrical connection. I do not know how that connection comes off. HELP! It an 1989 K5 so it has electrical fuel pump.
    matt
  2. msb350
    Jul 6, 2004
    96
    Texas
    Its a yellow connector and i dont know what is keeping it on and I do not know the proper way to remove it or how its removed. Sorry to post twice but this has to be done tonight!
  3. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    follow wires up from yellow plug. you will find black conector . unplug it. the yellow part in the sender is cliped in from the inside of sender.
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    My '87 K5 has 2 wires coming from the sender. 'Bout 2ft long; they go to a 2-pin Weather-Pak connector on the left framerail, just about in-line with the front edge of the tank. The darker wire (unsure of exact color...) is pump power; the lighter wire is the sender.
    Again, this is an '87 but I'd imagine it's pretty similar. Hope it helps...
  5. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Also, the ground wire bolts to the frame on the same side.
