Fuel pump wiring.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Big'nBadK5, Aug 9, 2003.
  1. Big'nBadK5
    Big'nBadK5 Registered Member
    Feb 9, 2003
    84
    Pjs, Ny
    I just put in a purolator electric fuel pump from pepboys and i am trying to get a hot lead off the back of the fust block that is hot whenever the car is in the run posistion. i jsut have no idea what to splice it onto. anyone have a wiring diagram of that fuse block? or just a definate place to splice it onto? thanks.
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    just get out a test light and find something thats powered on when the key is turned on...maybe a/c or radio, install maybe a 5 or 10 amp bigger fuse and splice into it...you should be ok
  3. dyeager535
    26,979
    Dunno what amp protection it needs, but if you tap into the *front* (cab side) of the fuse block there will be no splicing required, and it will be protected by a 30 amp circuit breaker. (which you can change to 10, 20, etc.)
    That's my opinion of course, I'm not a fan of trying to track down bad electrical connections, or having them fail on me at the worst possible time. Besides, if for whatever reason you need to cut power to it, using a "stock" accessory plug is easy, and makes sense to locate it there. Just route the wire through one of the existing firewall grommets.
    Being exposed to water, dirt, heat, etc., is hard on a connection, so in-cab is a better way to go anyways.
