Fuel Pump
Discussion in 'The Garage' started by Topdown, Oct 1, 2004.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Ok... I want to run a 750CFM Q-jet through my 350HO (vortec heads, performance intake, bigger than stock cam)... what the heck do I need to run for a mechanical fuel pump?
    6psi? 8psi? 13psi?
    80gph? 110gph? 130gph? 170gph?
    It seems like I should be able to run a 6psi 80gph fuel pump... but like everything else, there are so many choices and whatnot that its impossible to simply "go pick one up" and I definitely dont trust the teenager behind the counter at my local Schucks/Autozone/etc...
    I would like a rebuildable one if that helps.
    -Ryan
  2. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Believe it or not unless you plan on running high RPM (5000+) a stock fuel pump would do fine. Carbs use between 6 and 8 psi and you'll never need more than 100GPH. Hope that helps.
  3. Topdown
    Nov 26, 2002
    2,598
    /forums/images/graemlins/waytogo.gif
