Fuel Pump...
Discussion in 'The Garage' started by socal chevy, Feb 16, 2005.
  1. socal chevy
    socal chevy 1/2 ton status
    Nov 18, 2004
    308
    San Clemente, CA
    Id like to replace my fuel pump. Should I get stock or aftermarket? Any particular brand better than others? My engine is a 305, stock. Hows the install?
    Thanks!
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Electric or mechanical?
  3. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    good question.. I dont know. :confused:how do i find out?
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Look on the passenger side of the engine , at the bottom in front of the motor mount , right on the side of the block . If you have a mechanical pump , its right there . If you are carbed , one hose should go from this to carb , two to the tank , big one fuel from tank , small one fuel return to tank :k5: :k5:
  5. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
  6. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    You were logged in when you got that link, and I don't have your username and password, so it won't let me view the pic.
  7. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
  9. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    so is it mechanical or electric?
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Mechanical , if it was electric it would be in tank or mounted remotely like on a frame rail . The pump you have is driven by a pushrod that runs off the motor . More than adequate for a stock 305 , its all I run , waste of money to upgrade a motor that will be replaced later , for what its worth it will probably be fine on a 350 in a truck anyway if you ever swapped out the 305 . :k5: :k5:
  11. Can Can
    15,555
    156
    Cochrane, Alberta, Canada
    FWIW, I replaced my mechanical with an electric pump about 10 years ago after fighting with an on-going vapor lock problem. I noticed a small increase in high RPM power and have never vapor locked since the swap. I also like the fact that after the truck sits for a while, a turn of the key and a 5 second pause ensures that the carb is primed.
  12. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Not to hijack but did chevy ever have 3 lines coming out of there fuel pumps? (not counting pump to carb) Inlet, return, pressure relief?
  13. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    Ive tried looking online for a stock replacemnt. Can you point me in the right direction?... Do I need other parts for the replacement? Thanks!:D
  14. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the only ones that i have seen that had a vent were marine pumps.
    shouldn't need anything else, but it would be good measure to change the fuel filter, it should be in the carb inlet (if qjet)
    any autoparts store will have one, you can order it online from autozone if you want also.
  15. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Just drive to any auto parts store and buy one , and a gasket , cheaper than adding shipping to an online order . Then its just a matter of removing and replacing . Should be store stock for a 80's mechanical pump :k5: :k5:
  16. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    The pump should be very easy to find. I think I got mine at Schucks for less then $15. I've got one on my 350 with a 4-barrel holley and never run out of fuel.
  17. diesel4me
    Jul 24, 2003
    17,584
    945
    Massachussetts
    mine had 3 lines...
    The 86 305 motor I put in my 79 C10 came from a G10 van,it had 3 lines on the fuel pump,probably because it had AC,and they are more prone to vapor lock,especially in a van--I just blocked the small return line off with a peice of hose and a bolt with clamps,since my truck had no return line(and my vapor canister is no longer there)---.
    I prefer AC fuel pumps over other "cheapie" brands,but have used both-(airtex used to be decent too)-when I see an AC fuel pump on my 73 307 motor in my van thats ORIGINAL!--and the same with the one on the 305 in my truck,both have well over 100,000 miles on them and are still going strong--I havent seen many aftermarket ones last that long,and the prices arent that much higher for an AC pump...:crazy:
  18. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    ha
    I just replaced that fuel pump... It took me like 1 hour!!!! That F*cking rod is a little bitch, thanks giving me a heads up!! That was by no means easy either... that little pump is wedged in there!:mad:
  19. diesel4me
    Jul 24, 2003
    17,584
    945
    Massachussetts
    the magic bolt...
    Didnt anyone tell you the trick for holding the fuel pump pushrod out of the way??--before taking the pump off,you can remove the bolt in the front of the block that is in line with the pushrod,and screw in a longer bolt to hold the pushrod from sliding down(dont tighten the bolt too tight,just snug it down slightly,so you dont pooch the pushrod!)--then you can take the pump off and install the new one without fighting with the pushrod,or having to take off the plate under the fuel pump and use grease to hold the rod out of the way,or using feeler gauges or hacksaw blades to push the rod back where it belongs..
    Oh,and dont forget to put the original bolt back in the hole before you start it up!(it will wreck the pushrod if you leave the long bolt in!!-and leak oil like a seive if you leave NO bolt in it!)...:crazy:
  20. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    That information would have been very usefull BEFORE installing the pump..... Now I know. ;)
