Fuel pump?
Discussion in 'The Garage' started by pto blazer, Dec 27, 2006.
  1. pto blazer
    pto blazer Registered Member
    Jun 26, 2006
    5
    B.C. Canada
    Today my '89 Blazer (350 t.b.i.) was hard to start, it took a while, she turned over good but wouldn't start for a while, something she has never done before. Now she just won't start, I took off the air cleaner cover and poured in some gas, she fired right up and then died. Its the fuel pump, isn't it? I have never pulled a tank, never changed one thats in the tank. Is there anything else I could do or be missing? The fuel filter was changed less than two years ago, I have never put any questionable gas in her. Thank you, Jim.
  2. 90v1500
    90v1500 Registered Member
    Oct 1, 2004
    56
    Huntsville, AL
    Yeah, it sounds like the fuel pump:( . It could be the fuel pump relay though, check it first. Also try banging on the tank, sometimes that works...
  3. merace19
    merace19 1/2 ton status
    Sep 19, 2003
    372
    Mobile, Alabama
    I hated dropping the tank so much that i just removed the bed of the truck.
  4. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    i've pulled the bed on a '92 c1500 to swap fuel pumps, but for obvious reasons, that won't work with a blazer. honestly, the way the the tank is mounted and surrounded in these rigs, i'd almost be inclined to cut a hole in the floor to get to the pump...almost.
