fuel pump
Discussion in 'The Garage' started by b laub, Sep 11, 2003.
  1. b laub
    b laub Registered Member
    Nov 20, 2002
    45
    illinois
    so my fuel pump in my 89 k5 goes out on me and i put a new on it everything is hooked up exactly the same way it was when i took it out my k5 still wont start what would it be?? i checked the fuses but i didnot know witch one is for that or if there is one any thoughts?
    thanx
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Have you checked to make sure you're getting spark? Hook a timing light up to one of the plugs and see if it lights up. If not, the most likely culprit is the ignition module located under the distributor cap.
  3. b laub
    Nov 20, 2002
    45
    illinois
    um at first i thought it was that but i put gas down the throttle body and it fires up and runs for a sec and then dies so i dono what it is becuz i know i put everything back the way it was
    89 k5
  4. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    Does the fuel pump go on when you turn the key to the on position?
  5. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    Did you check your fuel pump relay? On my 88 it was on the firewall over by the air conditioner.
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    thats what it was on my 90. look under the relay cover (black and long 14" or so) there is a fuse in there.
    nathan
