Fuel Pump
Discussion in 'The Garage' started by Tshane, Oct 6, 2003.
  1. Tshane
    Tshane 1/2 ton status
    Nov 26, 2002
    144
    Peoria, Illinois
    Just got a fuel pump at auto zone for my 86 shortbed. The pump has 3 hose hook up. I know one is fuel supply the other is return. Is the third for the vent?
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
  3. Tshane
    Nov 26, 2002
    144
    Peoria, Illinois
    Is it needed?
  4. chevyjunky77
    chevyjunky77 Registered Member
    Oct 6, 2003
    10
    Ft. Campbell KY
    If you ripped out the emissions try looking at an older pump they only have two connections. I am not real current on the newer models so it may not even come close to working.If not plug it.
  5. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    all the newer marine small blocks run a pump like that. for those, it's a bypass for if the diaphram develops a leak, it runs up to the carb and dumps that overflow fuel into the carb at a port next to the fuel inlet... if the diaphram is undamaged it does nothing...
