fuel pump
Discussion in 'The Garage' started by BIGDAN112686, Dec 30, 2003.
  1. BIGDAN112686
    BIGDAN112686 1/2 ton status
    Nov 20, 2002
    112
    nc
    got a little problem(i think) with the fuel pump. when i turn my truck off it stays on. i tried unplugging the relay but it still stayed on. any suggestions, or is this normal and im crazy. thanks.
  2. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    What kind of truck?
  3. BIGDAN112686
    Nov 20, 2002
    112
    nc
    its a 1990 k5, tbi 350.
  4. dyeager535
    26,982
    191
    I'd guess maybe it's an ignition switch or oil pressure switch (or both!) problem.
    I know that as it's wired, if the relay fails, the oil pressure switch will "force" the pump to work once it sees oil pressue, but I think that whole circuit only gets its power from the ignition, so you'd have to have at least an ignition switch problem as far as I can see, for the pump to work after the vehicle is turned "off".
  5. BIGDAN112686
    Nov 20, 2002
    112
    nc
    i hadnt driven it for about 1 week or so. but i drove it, parked it at a friends house, and disconnected the battery while i was inside for about 30 min. after that. hooked it back up and everything is goin fine now. weird, but im still gonna keep an eye/ear on it. thanks for the info though
