Fuel pump?
Discussion in 'The Garage' started by shaun, Mar 8, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    Well I am pretty sure my fuel pump went out. I was in the middle of a wheeling trip this weekend and it died. When i turn on the key I dont here my pump and when I try to start it I see no fuel so I am going to change it. Did any one ever find the post where the guy cut out part of his floor rifght above the tank and built a trap door /forums/images/graemlins/hack.gif. I was going to do this butwas hoping for some measurements. If not I will do it and post measurements for anyone else. This sucks /forums/images/graemlins/doah.gif
  2. chevystepside
    chevystepside 1/2 ton status
    Sep 23, 2002
    147
    leadville colo
    before you cut a hole above the tank make sure that you have oil pressure. by that i mean make sure that the oil pressure sender is good. the ecm needs to get signal from the oil sender to keep the fuel pump running. also check your fuel pump relay.
  3. dyeager535
    26,979
    Make sure the pump is even getting power before hacking up the truck. Should be a two prong connector somewhere near the tank.
