Fuel return line questions
Discussion in '1982-Present GM Diesel' started by Shannon, Jun 26, 2002.
  1. Shannon
    Shannon Registered Member
    Mar 6, 2002
    6
    Kansas
    Looks like I have a fuel leak at one of the injectors. Third one back on the LH side. I don't see how a leak would develope between the fuel line and injector fitting and it doesn't leak right away, takes maybe 10 seconds to start dripping. I think it's the return hose. Looks like maybe 3/16 line. Do I have to find the braided line or will regular fuel line work? I don't see any type of clamp holding it on either, does it just slip on the injector barb? My Haines book isn't much help on this one.
    Shannon
  2. carolina custom
    carolina custom 1/2 ton status
    Dec 29, 2001
    161
    Mt. Pleasant SC
    Mine have spring loaded hose clamps. I got a set of new hoses and clamps from a standyne(sp?) dealer for around $30. The rear lines are a PITA.
  3. Shannon
    Mar 6, 2002
    6
    Kansas
    Thanks for the response CC. I will pick up a line kit tomorrow. Last night I picked up some 3/16 fuel line and found out the OD is too large. Won't fit between the barb and injector body. The old hoses just pull off on mine, no clamps. One end of the hose was cracked. I trimmed it back a little and put it back on. Seems ok for now.
    Shannon
  4. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    I had a very difficult time finding return hoses when I replaced all mine. The OD was either too big or the hose too small to fit over the injector nipple. I ended up finding Mercedes braided fuel line that worked excellent at a special auto parts store. He charged me 10 bucks for about 5 ft. of it. I got lucky. You can also get it from the dealer (haha) if you want to pay big bucks for it.
