Fuel return line...
Discussion in 'The Garage' started by Topdown, Feb 18, 2004.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    I was looking under my truck and found a hard line, roughly the size of my fuel line, open, sitting on the frame-rail... no cap, no rubber line attached to it... nothing.
    Is it possible that my 1972 K5 has a fuel return line?
  2. crawford
    crawford 1/2 ton status
    Feb 13, 2004
    229
    Vancouver, WA
    My '72 has the exact same thing. I have a electric fuel pump instead of the mechanical one now, so that may be why. It has been on my list to figure out what the deal is and get rid of it if I don't need it.
  3. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    It's for the charcoal canister.It's a gas tank vent line(emmision device).
    Goes from the tank via a hard line to the canister that should be located on the passenger fender,below the battery tray.
    The hard line stops and a rubber line would go from there to the canister.
  4. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    If you do run an electric fuel pump it is a good idea to use a return line. The constant fuel flow through the pump keeps it cool which is a good thing.
  5. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Here's a pic I took while installing my electric fuel pump when I did my TPI install.
  6. Topdown
    Nov 26, 2002
    2,598
    so since I have no charcoal canister anymore... can I use that as a fuel return line?
  7. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    That ie what I am thinking of doing. My canister is still there but I won't be using it for emisions anymore. I would think that it should work great as a return line.????
  8. Topdown
    Nov 26, 2002
    2,598
    it seems to make sense to me... if its a straight shot back to the fuel tank and there is no canister in the way. Is there a valve or something that would impede the flow?
  9. Burt4x4
    6,854
    I don't think so? It's just a vent for the fumes to go into, as far as I can tell anyway? The MPFI I am putting in requires a return line so My plan is too use that line.I will blow some air thru it with my compressor just too make sure it is clear /forums/images/graemlins/thumb.gif
  10. Topdown
    Nov 26, 2002
    2,598
    cool /forums/images/graemlins/thumb.gif that may solve the problem super fast and easy... when you blow some air in it, post back up what you find. I'll buy you a beer some day /forums/images/graemlins/woot.gif
  11. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    haven't followed that line back to the tank.If you use it as a return make sure it doesn't interfer with the venting system of the tank.
  12. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    Exactly. Make sure you have a vented gas cap. Usually stock caps are sealed so the vapors have to go to the charcoal canister. The last thing you want is gas fumes to build pressure in your tank. I just put in a new tank and sending unit in my '79 and I seem to remember there being some type of valve at the vent port that goes to the charcoal canister. But my sender had a separate nipple for a return line.
  13. Burt4x4
    6,854
    Hmmm, well on my 72 I have 3 other tubes connected to my tank besides the fuel line. Two goto the metal tube thing in the rear drivers side quaterpanel near the tail gate. The third is the one we have been talking about. I'm not sure if the meatal tube thingy is a vent or some kind of ?????
    I agree there must be a vent, wait I think the filler tube has a vent tube also?? Oh now I gota go look.....
  14. Topdown
    Nov 26, 2002
    2,598
    the filler tube is a tube within a tube. I think thats where it vents... aside from that, I am not 100% certain that it even really ever seals with my gas cap on /forums/images/graemlins/grin.gif
    It would be so kick-ass if that extra tube was able to be used as a fuel return
  15. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    There is a vent in the filler neck tube, but that is only used when pumping gas. Once you put on the gas cap that vent gets covered. My sender had 4 lines coming out of it. 1 was the vent to the filler neck, 1 was fuel supply, 1 was fuel return, and 1 was vent to charcoal canister.
  16. Topdown
    Nov 26, 2002
    2,598
    did you ever figure out if it has a vent?
  17. Burt4x4
    6,854
    Well that pipe that is mounted next to the filler neck is sealed? Not sure what it's function is? The filler neck is vented but only when the cap is off.
    I still don't know for sure what I am going to do for a return line but I will let you know what I do. /forums/images/graemlins/thumb.gif
  18. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Just FYI for you guys - I did a new return line on the TPI406 setup for my K5 with a braided stainless hose.......there's no pressure to worry about, mainly just have to watch for routing it properly to avoid abrasion and catching it on things. Just tuck it up inside the frame rail and you're good to go. Pic - you can see the hard plumbed line I did for the pressure side - new 3/8" all the way from the filter to the factory TPI hose hookups.
  19. BigJohnson
    BigJohnson 1/2 ton status
    Jan 22, 2001
    207
    AL
    BurbinOR, what filter were you running in that picture? I am about to re-plumb my rig for EFI and I am trying to find a good inline filter to use.
  20. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Looks like part number FF504....GM used them for lots of applications for a long time. even the new 8.1 litre uses that filter.
    Blake
