fuel sender??????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tightwork 82 K5, Mar 5, 2002.
  1. tightwork 82 K5
    tightwork 82 K5 Registered Member
    Oct 15, 2001
    47
    orlando, florida
    I do not see any wires comming from the fuel tank. I have an 82 k5 and the gauge is way past full all the time. where is this connection located. I know on top of the tank but is it a male prong sticking out or does the wire go inside of the tank???
  2. Storm Trooper
    Nov 24, 2000
    4,640
    I'm not sure about on a "82" but on a "87" it is in the top of the tank with the fuel pump. Should only be 4 wires, 2 for pump & 2 for sending unit. $.02
  3. TIGHTWORK82 K5
    TIGHTWORK82 K5 1/2 ton status
    Oct 21, 2001
    140
    orlando , florida
    Ihave a mechanical fuel pump???? and no wires just hose comming from the tank!
  4. dyeager535
    26,979
    pink wire is gauge wire from top of tank (sending unit), black is ground, should be bolted to frame right near the tank.
