Fuel Sender
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Me89'Jimmy, Jun 2, 2003.
  1. Me89'Jimmy
    Me89'Jimmy 1/2 ton status
    Oct 6, 2002
    127
    Sykesville, MD
    Ive got an 89 with a 350 TBI and the gas gauge is broken, the problem is the fuel sender is shot. LMC wants 300 dollars for it /forums/images/graemlins/eek.gif and no other parts stores i know of will sell it for less than 200. Can you guys give me a hand on this one
  2. dyeager535
    26,979
    First off, did you make 100% sure its the sender? Not the ground, not the sending unit wire, not the gauge, and not the printed circuit board?
    If you've done that, do a search for a repair procedure posted not more than two weeks ago for sending units.
    Finally, if that fix doesn't work, someone can probably post the GM part number, as I recall someone looking them up on GMpartsdirect.com for just over $100.
  3. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    junk yard. or the parts for sale section. they usually dont go bad... mine was original from 79 and it was fine up till the day i scrapped the tank.
