Fuel sending unit
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LittleJoe, Jan 2, 2007.
  1. LittleJoe
    LittleJoe Newbie
    Dec 25, 2006
    Eagan,MN
    The fuel gauge on my 1986 M1008 pickup reads very radically. I want to replace it but I don't know, Is there a difference between a sending unit for diesel and gasoline?
    :confused:
  2. dyeager535
    26,975
    Have you verified it is actually the sender, and not the gauge or associated wiring?
    If you have not done so already, search for threads regarding fuel gauges and repair/testing.
  3. sweetk30
    Nov 1, 2004
    25,529
    527
    horseheads , ny 14845
    comon ground problems. wire at sender or wire at frame point problems. check them first.
  4. PerdidoK5
    PerdidoK5 1/2 ton status
    Jun 10, 2002
    108
    Pensacola, FL.
    A sender is a sender... Short the sender out, it should peg full. If it does, good sender. Then the search is on for a faulty connection or a bad wire.
