fuel supply and fuel pump questions
Discussion in 'The Garage' started by dirtwarrior17, May 11, 2005.
  1. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    I changed my plugs last night and they looked like they had been in a chimney and not a motor. Right now i am running the accel 45 psi pump on my tbi setup with no inline regulator. Holley says their tbi comes with a 9-22 psi adjustable regulator but i can't figure out how to adjust the thing and i need to get a better inline regulator anyway. My gripe is that i just paid 3k for this motor and all the aftermarket stuff and i can't get it to even run. It fires up REAL strong then just never stays running... its run without the air cleaner on but when i put it on it just fires up for 2 seconds and sounds like it floods out.
    What adjustable regulator should i get? Is there one with a spot to put a guage?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    http://www.cfm-tech.com/ have adjustable regulators and guages. The adjust should be on the injector pod somewhere. Been so long since I've messed with a TBI throttle body I can't picture it.
    What injectors are you running? The Holley ones? Just wondering if you had 454 injectors or what.
  3. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    I just called holley and they said i have to drill into the cap and pull it off then i can adjust the psi.
    Is there a fitting that will mount right up to my 5/8 line and work with a 1/8 gauge. Or should i go down to ace and piece together an adapter?
  4. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    Its the ones that come with the holley 670 cfm tbi... 80 pph IIRC. I just pulled the air cleaner off and found out why it wouldn't start... 2 blown injectors!
