Fuel System Ideas?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by laketex, Nov 21, 2000.
  1. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    I think I'm gonna buy a fuel cell for my blazer. I'll put it right up against the tailgate after I bob off the rear end. I want to run a filler tube to the outside, possibly using a stock filler door operation. Mount it to the floor.
    That's phase one, no problem there.
    What I need to know is what lines, hoses, ect do i need to make this work? Does gravity play any role in the running of lines or can I exit the tank, go straight down thru the floor and run in the stock location to the engine? I know NOTHING about fuel systems except for hearsay that they're tricky. Any advice or help would be greatly appreciated.
    Bryan
    Durant, Ok
  2. laketex
    6,220
    North Texas
    Allright, I'm not letting this get to the second page yet. Yeah I know, it's cheating, oh well. Get over it. here's the page of the cells i'm looking at:
    http://www.jazproducts.com
    The pro sport, pro sport 2, circle track, remote fill, and pro trap all have a 32 gal tank option. Plenty. Could use some advice on what to get there as well. The metal ones are cool, but the plastic ones are cheap. WHAT TO DO....
    Durant, Ok
  3. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    ok here goes,,
    when you hook up your fuel cell you will need a "to" and "from" line!!!!one going to the fuel pump and one returning from the fuel pump,,and even possibly on returning from the carb....beings the fuel cell will be inboard you might consider on one that has a bladder in it so if somehow the tank get's cracked you won't have raw fuel in the cab...the plastic tanks should be all you need and you can even add other lines from it just by drilling and adding an outlet for I.E. washing your hands on the trail after a fix or lighting that all important camp!!!fire!!!it really depends on what you prefer....happy hunting
    ANYBODY LOSE THEIR JEEP????????[​IMG]
    I JUST FOUND ONE UNDER MY BLAZER!!!![​IMG]
    [​IMG][​IMG]
  4. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Laketex, seeing how the rats most likey have eaten through all your hoses, I'd go witha electric pump, mounted close to the cell. and a return from the carb (for overflow purposes)and run all new lines under the truck
    Your bud WK
  5. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    I don't care how well the fuel cells are built, I wouldn't want one in the truck with me!
