Fuel Tank Baffle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DukeBoy88, Jan 12, 2003.
  1. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    I removed my tank to install ORD's shackle hangers and found the plastic baffle "tray" inside the tank partially broken and floating around the tank unattached. The tank had its fair share of crud as well, so I'm going to clean it as well as I can, possibly reseal it. My question is can I remove the baffle, or is fuel slosh going to give me trouble. or is there a way to reattach it to the floor of the tank? I found replacemnet tanks in JC whitney for $150 and plastic replacements for $190, but didn't know if they were neccessary. thanks in advance.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i know of no way to reattach it to the bottom of the tank. being a tbi you might have a problem when you step on the gas or brake hard, it might surge as the gas is going away from the pickup. but this will only be when it is about 1/4 tank or so. if it was carburated it wouldn't surge because it doesn't need the psi to stay runnin.
  3. dyeager535
    26,975
    BlazzinOR (SP?) was running his truck without a baffled tank as I recall.
    No, you can't reattach it, nor can you glue the plastic back together. Had a friend that works for a plastic company check that out for me, the plastic is too fuel soaked by now.
    You can get brand new ones for around $135, its up to you.
    Don't forget that *hills* (steep, not gradual) will cause problems when fuel level is low enough, not just braking and accelerating.
  4. ds350
    ds350 1/2 ton status
    Jan 26, 2001
    190
    Bay Area
    Time to replace the tank /forums/images/graemlins/deal.gif
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I am going TBI on my engine and I have saddle tanks that I believe don't have baffles, so I am building a small 5 gallon tank that will be fed by the other tanks so I will have no fuel starvation. Kind of like an intermediate tank.
    /forums/images/graemlins/thumb.gif
  6. DukeBoy88
    Oct 16, 2002
    315
    Jonestown Pa
    Hadn't thought of that, where are you mounting the intermediate tank? will it be float controlled to the other tanks?
  7. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    Your putting the pump in a 5 gallon tank? Aren't you worried about caviating the pump and screwing the pump up?
