fuel tank filler hose ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Nov 6, 2002.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    where can we get new saddle tank filler hose for pass side 73-78 ?
    it is special hose material, correct ?
    thanks for anything
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Napa sells fuel filler hose by the foot.That would probably work for ya.Its cheap too /forums/images/graemlins/grin.gif
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    how flexible is it ? will it turn a 90 turn ? or do they have misc pre-bent pieces ?
    thanks
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    they dont have anything that will work the ones they have wont flex without kinking and tey have no prebent ones, i went over there to inquire.
    thanks for anything further.
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    What I do is go to Kragen and I look into their radiator hoses. They have a selection of prebent hoses and I just try and find somehing that will do the trick, most of the times I have to cut a piece of.
    I did that for my jeep, blazer and even my bike filler hose.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    cant use radiator hoses for fuel, they dissolve. and kragen doesnt exist in midwest anyways,.
    thanks
  7. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    No, don't use radiator hose.
    I bought new filler necks from LMC and they fit perfectly, no problems, all prebent.
    -- Mike
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ordered from LMC over the phone just now, 50 bucks for both of them,,,, doenst look like any other place carries these hoses,. looks like they have a monopoly on parts like this.
    thanks
  9. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I used fuel hose for that, from the local Autozone. LMC sells it too, but why pay the premium?
    -- Mike
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    what year truck you have and for what year hose did you get ?
  11. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    My truck (longbed pickup) is a 73, but I have a bed from an 87 on it.
    I got the filler neck for an 81-87.
    -- Mike
  12. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    hmm see im wondering if i should have ordered it for a 74 like i did
    heres my specs:
    tank being swappe don truck: 74 pass side
    truck year: 81 without pass tank originally, no door or even hole for a filler neck in the bedside
    are filler tube diametersd same 73-81 as in 82-86 ?
    somewhere around 1 1/4" is what i measure on the 74 tank
    what you think ?
  13. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I would think you need the same filler neck as I got, the 81-87.
    LMC has some decent pics of the configuration of the filler necks. If you don't have a catlog,m go to lmctruck.com and they'll send you one free. They show the difference between the earlier and later filler necks and you can decide.
    -- Mike
  14. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    79-81 differs from 82-up 81 was last year on fillers, i dont know why. 73 and 74 are different from 75-78 also, its complicated,,
    thanks
  15. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Is there any reason you don't buy parts from the dealer ? More people waste time trying to half ass their stuff together with universal parts store garbage. Go to Chevrolet one time and get the correct hoses. Problem solved. /forums/images/graemlins/eek.gif
    Jim
  16. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    no, actually problem not solved, GM discontinued basically everything and a long time ago, the dealer was the first place i went to, thhey couldnt even find out part numbers on most of the stuff cuz it has been long discontinued. GM rarely has any parts anymore, seems like these days they simply send them back to GM Corp when they get only a few years old now. you may be able to get soem parts there for your 88 there, but not you cant for anyhing this old i am working on., going to dealer for parts for old vehicles like this oesnt work these days
    why did you assume i havent gone there ?
    i might as well quit going there, the only thing GM has ever had that ive gone there for in the past was a turn sig switch asembly- even though was later style one and required an adaptor) and a PCV valve cover grommet, and thats it... GM dealer parts counter sucks for parts availability.
    thanks
