fuel tank leak and factory ujoint question
Discussion in 'The Garage' started by alec78, Mar 17, 2003.
  1. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    Two questions:
    1) I have a small crack in my fuel tank. So small it leaks about 3 drops a day (so far). Anyone know a temperary fix just until I can replace. FYI its a diesel.
    2) Is a propane torch hot enought to melt the plastic injection on factory u-joints?
    Thanks!
  2. Bruiser
    Bruiser 1/2 ton status
    May 21, 2000
    320
    Caldwell,Idaho
    J-B weld makes a product that will dry even when it is wet or has fuel on it just for that reason. J-B weld is great :P
    hehe
    J-B weld waterweld
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    There is gas tank repair epoxy...mix the two putties together and then spread it over the leak area. It will work if there is gas present at the time too. I think it's a Permatex product, but not sure on that.
    Yes, a propane torch will work fine to purge the plastic out of the d-shaft...that's what I used on mine. /forums/images/graemlins/thumb.gif
  4. Larry_in_Tx
    Larry_in_Tx 1/2 ton status
    Oct 24, 2002
    404
    Houston Tx.
    I can't help you with the fuel tank but a propane torch is hot enough to get that nylon out... and it smells like poo.
  5. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    I had a leak in my diesel tank a few year ago, I just rubbed a bar of soap into the crack (the soap doesn't disolve very fast so it stops the leak for a while). Then I just cleaned it up with some solvent and a wire brush and epoxied a quarter over the hole. Worked great!! /forums/images/graemlins/cool.gif
  6. alec78
    Aug 5, 2002
    358
    Washington
    THANK YOU ALL!!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    The good to this bad side is now I can fix my front d-shaft!
