Fuel tank location? with --->pics
Discussion in 'The Garage' started by Stomper, Mar 9, 2003.
  1. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    I'm putting a 27 gallon K5 fuel tank in my K10 short box. I"m concerned about having enough clearance between the tank and the diff. There is 11" between the diff. and the tank (dry tank, no box or 42" spare and on and on ). Granted I won't get 11" of compression with both springs at the same time and I don't think flexing will make it hit either but I still have some doubts. The suspension is 3 leaf 57" springs with overload, 1" homemade zero rate, axle moved 1" to the rear, ord shakle flip moved to the rear 1 3/4", stock shakle. Here are the Tank pics Do you think I'll have a problem?? Thanks in advance /forums/images/graemlins/thumb.gif
    Stomper /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    You'll be fine - that looks like plenty of room. You'd have to flatten both springs in order to get the pumpkin up that high - and I doubt that will ever happen off-road. /forums/images/graemlins/thumb.gif
  3. One_Ton_k5
    One_Ton_k5 1/2 ton status
    Jan 30, 2003
    168
    St Paul Minnesota USA
    You could also put in some bump stops to keep the axle down from the tank....
  4. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    hey that looks good! im planing on doing a similar fuel tank swap in my K10. when you get it all done will you tell me about any problames/hang ups you had? so i know what im in for?
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Actually, I think you may have problems, that thing is going to squat way down with weight on it. I've got about the same setup with the tank raised 2" and I added a bump stop that does get hit. Basically, I just hung a cross member right at the front of the tank and put a standard rear axle bump stop so that the tip was in the center. It hits my C14FF about 1.5" before the tank and I've hit it several times. In fact, I bent the 1/4 bracket that holds the bump and had to straighten it and add gussets.
  6. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    Were you going to add a body lift? If so, you can always move the tank up the same amount as the body lift. You will need to engineer a new inner frame ledge for the tank to rest on, and then shorten the tank straps. I did it on my 71 and it looks great from the back having the tank nice and high. JT /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  7. Stomper
    May 11, 2002
    3,767
    Iowa
    I am planning on a 2" body lift. So I may be able to raise the tank some. In those pics the tank flange/seam is under the frame. If I put it over the bottom frame rail it will be over 2" higher. I can also relocate the frame cross member behind the tank all the way to the end of the frame which will move the tank 5" back. This will also make for better shock mounts on the axle. And I will be putting the bump stops back on. Thanks for the replys guys! /forums/images/graemlins/thumb.gif
    Stomper
