fuel tank problem?
Discussion in 'The Garage' started by 82K5_6.5L, May 17, 2005.
  1. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    so was out playing around the other day and on the way home, my fuel gauge went all the way past full almost laying on its side, and doesnt ever move.. and i know i dont have that much gas.. what could this be? the sending unit or something? btw 82 k5 w/ 31 gallon tank.. thanx
  2. blazerguy 90
    blazerguy 90 1/2 ton status
    Nov 12, 2004
    126
    EL Sobrante, CA
    I have the same problem on my 90 K5, I had an extra fuel gauge, so I tried that, it made no difference. I ordered a new sending unit from LMC Truck, it should be here tomorrow.
  3. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Did you knock the ground wire off?
  4. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Same thing happened to mine, the ground wire comes off and it goes to the 3 oclock position.
  5. 82K5_6.5L
    Dec 4, 2002
    439
    Tucson, Az
    oh really?? this is what mine is doing! tell me more about "said ground wire" where, and how do i fix it? thanx!! :D
  6. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    The ground wire comes from the sending unit on top of the tank and attaches to the frame right in front of the driver side rear tire. If it is connected still, try taking it off, brush the rust off the frame around the bolt and reataching. If its not connected, connect it :grin:
  7. 82K5_6.5L
    Dec 4, 2002
    439
    Tucson, Az
    damn! that sounds hella simple.. i will definitly be doing that tomorrow.. thanks, u kick ass!
