Fuel tank Question????
Discussion in 'The Garage' started by Supreme70, Feb 24, 2006.
  1. Supreme70
    Supreme70 1/2 ton status
    Jan 19, 2005
    501
    Detroit, Mi
    I was wondering if anyone knows if the fuel pump on a 87 with t.b.i. is in the gas tank. the reason I ask is I have dual tanks and when on my left tank the truck runs great, but when i switch to the right tank the motor acts likes its running out of fuel, any help would be appreicated.
  2. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    Pumps are in the tanks, yes.
  3. sweetk30
    Nov 1, 2004
    25,536
    532
    horseheads , ny 14845
    also it could be a bad switcher valve.
  4. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    how would i know if the switcher valve is bad??? should i just change the pump and then see how it acts
  5. sweetk30
    Nov 1, 2004
    25,536
    532
    if the lines arnt to bad just try to by pass the switcher and see if it runs good . or remove output line from sender to switcher valve and install pressure gauge and see what pressure you have. line pressure before regulator should be in the 16-18 psi range.
