Fuel Tank Relocation on DD 89 Sub
Discussion in 'The Garage' started by bigbluesuburban, Jan 29, 2007.
  1. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    I have 89 Sub and the gas tank is between the frame rails in the rear. I am considering doing something different with that space, but in order to make that happen I would need to relocated the fuel tank.
    I would like to try and use stock Chevy parts as much as possible.
    So what would my options be?
    Saddle Bag tanks? What years? If these were from a Carb truck then how to I deal with the EFI?
    Inside the frame rails or outside?
    Dual Tanks?
    Any ideas, cautions, suggestions are greatly appreciated.
  2. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    I think its all gonna be custom. you might could use some short 16 gal tanks under the sides, the tbi sending unit will work in the regular tanks. otherwise, you could do like me, i'm going to use a 57 chevy truck tank between the framerail and driveshaft on the driver side. thats the only thing I've found that would fit thats stock, or anywhere close. what are you gonna do with the normal tank space?
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Make sure to post up if you actually do it. I would be very interested in that write up.
  4. bigbluesuburban
    Feb 8, 2006
    1,362
    Well I am thinking about one of these...
    OR Actually one of these... cause it hides away better...
    Cause it looks like this when stowed...
    The only mod that I plan to make is to add a reciever to the tow unit so that I can still haul a trailer... AND... I can level the trailer no matter what!!!
    This is just an idea I have. Time will tell if I go this direction.
    Oh and the unit needs to go where the fuel tank is now so that is why I am looking at relocating it.
  5. bigbluesuburban
    Feb 8, 2006
    1,362
    TTT
    There is a lot of activity these days... And new threads make it to the 3rd page really quick.
