Fuel Tank Sending Unit p/n?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GaBnn3, Sep 17, 2005.
  1. GaBnn3
    GaBnn3 Registered Member
    Jan 2, 2005
    90
    Holyoke, Ma.
    I have a 1988 V-10 Suburban w/40 gal tank. My manual shows a part number of 25090873 for what is called the Fuel Tank Meter Assembly. I haven't tried this part replacement before and can't find this p/n at the discount GM dealers is use on-line. Can anyone help or explain. Thanks.
  2. dyeager535
    26,979
    Typically that means the part is discontinued. :(
    That seems odd, but not impossible...a 1985/86 40 gallon sender is still showing as valid at gmpartsdirect.com.
    Double check the number, and also call your local dealer parts department...sometimes they will be able to locate one sitting in inventory somewhere even after the part has been discontinued.
    Places like gastank.com carry all sorts of senders, if GM doesn't have it, they might.
  3. 5kerblaz
    5kerblaz Registered Member
    Apr 25, 2005
    14
    Colorado
    Yep, discontinued. For the most part GM makes parts and dealerships will carry parts for 10 years. Sometimes you can get lucky and find a part at a dealership, but you'd have better luck with the sites Dorian listed.
  4. ike
    ike Registered Member
    Jul 5, 2005
    96
    orange ca
    Check Classic Industries
    Check Classic Industries in Huntington Beach CA 888-254-1157
  5. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    25090873 Is replaced by 25094553. Still available. List price is around $250.
