Fuel tank sending unit wires pulled out?!?!?!?!?!
Discussion in 'The Garage' started by fad2blk99, Sep 9, 2004.
  1. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I broke the plastic clip that runs the wire throught the top of my gas tank sending unit. I by passed the plastic contector by splicing the wire togther and sealed the hole once occupied by the connector with Permitex Black OEM GM style sealent. I also wet-sealed the splices with sealant. You guys think it'd be okay (safe) to run like that? Will the sealent withstand and occasional spash of fuel or should I go try to find a junk yard sending unit?
  2. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
  3. diesel4me
    Jul 24, 2003
    17,561
    940
    Massachussetts
    Gas will eat the RTV after awhile--J-B Weld will work though--but if you can get a new(or used )sender,that would be the correct way to fix it--even J-B Weld isnt always permanent when exposed to solvents for a long time--I know pulling the tank is pain,but gas leaks are dangerous and expensive--at 2 bucks a gallon,I make sure all I buy gets to the carburetor!. /forums/images/graemlins/crazy.gif
