Fuel Tank Switching
Discussion in 'The Garage' started by k20, Jul 22, 2004.
  1. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Ok this is driving me nuts, I have 3 fuel pumps on my truck. I have dual tanks, each one has a stock in tank pump, and then I have a hi-pressure pump on the frame rail. When I run on the left tank all is fine, when I switch to the right tank, the system loses about 4psi and the frame rail pump starts making a high pitched screaming sound, like its not getting enough fuel to quiet it. I replaced the fuel switching valve (had a warranty on the one that was on the truck anyway) and it fixed it for about 4 days. Well its doing it again. The book I have only has wiring for the carb'd trucks fuel tank systems, and they dont have in tank pumps. I have checked everything I can think of, and for it just to start doing it again, what gives? Any ideas?
    Also, when I switch tanks the fuel gauge never moves.......
  2. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    Check the voltage in your wiring to the switch and your fuel pump on the rail. Make sure it is 12 volts. If it is too high or low it can damage your pump and/or switch.
  3. hanger
    hanger Newbie
    Jun 29, 2004
    PULL THE PUMP FROM THE TANK (ITS NOT FUN)AND LOOK AT THE "SOCK" ON THE END OF THE PICK-UP TUBE. THE ARE A PRE-FILTER AND I HAVE HAD THEM PLUG. THE FIRST SIGN IS USUALLY THE PUMP STARTS TO WINE. IF THE PUMP IS THE STOCK ONE FROM THE FACTORY YOU MIGHT WANT TO GO AHEAD AND REPLACE IT SENCE YOU WENT TO ALL THE TROUBLE TO GET IT OUT....
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    well to the switch hasnt had any mods, the fuel pump on the rail is spliced in per edelbrock instructions, into stock wiring, so should get same voltage as stock pumps.
  5. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Chris if you want me to scan that that stuff like we talked about give me a holler..
