Fuel tank vent line
Discussion in 'The Garage' started by towdriver80, Feb 26, 2005.
  1. towdriver80
    towdriver80 Registered Member
    Jan 16, 2005
    41
    Maybrook, New York
    I was under the truck and spotted leaking fuel lines in the rear. I`ve replaced them several times since ive owned the truck. I hate salt!:mad: This time I`m using stainless tubing, found 50' rolls in the sizes I need. Definately not cheap. Right now the emissions are gone, no more charcoal canister. The fuel tank vent line runs to the front, joins the other vent lines and ends all the way up the firewall. Anyone know if I`ll have a problem if I just seal it shut at the tank? The stainless is expensive, but I don`t want any kind of a fuel starvation problem. I think the vent line with the fuel filler tube sould be enough, right? I cant just leave the tank vent line open at the tank, the truck runs alot of deep water. The truck is a 79K5, regular mechanical fuel pump, w/ supply and return.Truck avenger carb.
  2. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Did that to my '82 and when it got hot weather it built up pressure and blew off the fuel line, and alot of fuel until it depressurized itself. Doh!!!!!:doah:
  3. towdriver80
    Jan 16, 2005
    41
    Maybrook, New York
    If I went to the parts store and got a gas cap for a pre-emissions truck, would it would have some way to equalize pressure?
  4. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    the cap should be vented if its pre-emissions
  5. towdriver80
    Jan 16, 2005
    41
    Maybrook, New York
    Thanks. In NY anything older than 26 years is exempt from any emmissions requirements. I`m throwing a party.:D
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Well, I drilled a hole in the cap. Worked for me!
  7. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Which is higher off the ground, the fill cap or the vent tube at the firewall? I'd use the highest one.
    FWIW, I put a plastic in-line fuel filter on the ends of my tank vents. The one on my Dune Buggy actually hangs out of the right front fender where it's visable behind the tire. I've had people warn me at stop lights that the my fuel filter is disconnected. :whistle:
  8. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Bwahahah. that's hilarious:haha:
  9. towdriver80
    Jan 16, 2005
    41
    Maybrook, New York
    My gas cap and the vent on the firewall are only off by a couple of inches. I`m going to run the tubing and keep the fire wall vent. Somday I hope to run some kind of snorkel, and itl be easy to run the vent lines to it. This brought up a couple of good questions, though. Is the gas cap waterproof? When the pump sucks fuel from the tank, it has to get replaced by air. If it comes from the gas cap, it couldn`t be waterproof. If it comes from that vent line, I shouldn`t have run it with the other vent lines, I might be sucking crap from my tranny/t-case/axles into my gas tank. anyone know which one the make up air comes from?
  10. diesel4me
    Jul 24, 2003
    17,545
    936
    Massachussetts
    No Smoking!
    I had used an old gas filter as a way to vent a tank and keep crud out of the vent line--but be aware in hot weather the fumes coming out of the end of the vent line are exremely flammable,and having yours in the area of the wheels isnt a great idea--all it would take is someone to toss a ciggarette butt out the window and your tire to run it over and "WHOOF":weld: :yikes: --I'd put the vent up high under the center of the vehicle ,like the stock location....less exposure to outside spark sources...:crazy:
  11. dyeager535
    26,978
    Older caps are SUPPOSED to be vented easy, I checked some parts books, and caps for a 1973 truck were listed as being the same for a 1986. That is definitely incorrect. I couldn't find any that easily let air *out*.
    I've got an old cap which is vented easily "both ways", and it still builds up pressure. I'm not sure quite why, I haven't pulled it back off and checked the cause, but is obviously an entirely different design than the later ones, it has two seperate valves.
  12. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Both the '82 K-10s I had and my wife's '86 K-5 hissed/hiss when opened in hot weather. Definitely pressurized, but after I drilled the cap out on the K-10 it didn't do that anymore.
    The return line from the carb and the evaporative canister are the way it is normally vented. If I'm Thinking Correctly.
  13. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Yes, in a smog vintage the canister is the only vent. They want any hydrocarbons to be caught by the canister and not be allowed to escape into the atmosphere.
  14. towdriver80
    Jan 16, 2005
    41
    Maybrook, New York
    Thanks for all the info, guys! If that gas cap is waterproof, I`ll leave it alone. I`m going to re-run the vent line to the front, and keep it seperate from the axle/tcase/tranny vent line.
