Fuel Tank.
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by grendel, May 3, 2004.
  1. grendel
    grendel 1/2 ton status
    Jul 5, 2002
    287
    Boston, MA
    Howdy all,
    I have a 71 K5. I just pulled down the aftermarket fuel tank. It's a weird job that has four tubes welded into the thank, that go from top to bottom. The mounting uses four LONG carriage bolts to bolt to the floor of the tub.
    Any ideas on who made this?
    Also, what do you all suggest for a tank replacement? I plan to add TPI...
  2. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I have a 31 gal tank off a 90's K5 that one day I will put in, just have to work the inlet tube to point to the drivers side. /forums/images/graemlins/hack.gif
  3. grendel
    Jul 5, 2002
    287
    Boston, MA
    I suppose it wouldn't be too hard for me to place it on the other side.
    The hole in my body on the left side is already filled.
    How do they attach?
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    I also did the same, I have some pics i can send you. you have an email?? or I'll post sometime later this week so you can check them out.
    ARQ.
  5. grendel
    Jul 5, 2002
    287
    Boston, MA
  6. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
  7. TONYP
    Aug 13, 2002
    2,116
    so cal
    did you turn the filler neck, /forums/images/graemlins/grind.gif /forums/images/graemlins/hack.gif or is the big hose I see how you did it...
  8. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    I turned the whole tank around. /forums/images/graemlins/hack.gif
    ARQ.
