Fuel tank
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lukerz, Jun 27, 2001.
  1. lukerz
    lukerz 1/2 ton status
    Apr 13, 2001
    109
    Western Mass
    Hi all,
    I have questions about my fuel lines. I have two lines on my fuel pump and two lines on the tank. I was thinking about installing the canister but I don't know where all the $@#$@ lines go to. Is it just ok to directly hook up the large line to fuel pump and the small line direct as well? Looked in my manual and it is no help at all.
    Luke
    83 K10 from 76 K5 & 83 C10
    Th350 Np203 355 CID
    31 X 10.5
    Plan on 2" body lift
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    The canister hooks up to the third line that you are missing from the tank. My 79 has three lines from the tank. On large and two small. The large is the fuel feed. One of the small is the overflow (bypass) return from the fuel pump and the other is the vent that goes to the canister (part of the pollution control). Hook up the lines big to big, small to small from the pump to tank. Forget about the canister. Use a vented gas cap or you have fuel feed problems. Another option is to get a newer sending unit with the three lines.
  3. lukerz
    Apr 13, 2001
    109
    Western Mass
    Wow this is great news.Just buy a vented gas cap. Thanks so much.
    Luke
    Th350 Np203 355 CID
    31 X 10.5
  4. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Unless you have to pass emissions test. With a vented cap you will fail. Just fyi.
