fuel treatment/octain booster/carb cleaner
Discussion in 'The Garage' started by CHEVY 4WD, Sep 25, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Well im gonna try cleaning on the carb try to get a little better gas miliage... its a Old quadrajet but the motor isent bad I planed on spraying some carb clearner all though it and putting some octain booster or fuel treatment in the gas... what do yall think of this stuff? Ive never been a fan of additives but if it works I guess I could try it out, my major consern is that I DO NOT want to harm the engine in ANY way... were I work we have some marien fuel treatment that everyone at the store uses and likes but I just wanted to see what yall think /forums/images/graemlins/confused.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A total waste of money in my opinion. If you don't need the additional octane, why run octane booster? More octane doesn't clean better or anything. As to fuel treatment...that stuff is already in your gas. You don't need to add any more.
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    i have some carburetor pre-tune up cleaner...you can suck it up through the pcv tube into the intake and it cleans the intake really well..also in the spray version of the same thing you can make a carb shine on the inside...what about ATF?
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That stuff rules!!
  5. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    well I know the octain boost(it only raises your gas 1 octain) inent gonna do that much performance wise but I have heard of trucks running better after they ran it though 1 time.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would bet it was the owners imagination.
  7. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i dunno but i sure would like to get more milage out of my truck! mine drinks gas like crazy...i thoguht taking the holley of and putting a quadrajet on it would help things out a tiny bit but there the same if not worse! i dont know what else to do.
  8. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Get yourself some ChemTool! Drop some in the tank and buy a spray can for the carb and choke linkage. Octaine booster is just a waste of money IMO.
  9. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    if you really really want octane boost, run some kerosene in your tank. don't laugh... read the MSD sheets off the bottle, thats all the octane boost are is kerosene.
    get the "fuel system cleaner" from berryman b12 or hyperlube
  10. Grim-Reaper
    7,385
    Atlanta
    Top end Engine cleaner from the dealer. It will remove carbon from the valves and pistons. Removing the carbo on the valves will help intake flow. removing carbon from the pistons will help prevent pre ignition, ping, and run on problems.
    Good tune up and verifying the carb is set correctly is going to do more for MPG then anything else. Meter the plug wires as well. Bad plug wire will function but not well and will cause a weak spark and not get full ignition when you want it.
    What are you getting now and is your speedometer even acurate? I know mine is way off from regearing and tires size changes.
  11. micah
    micah 1/2 ton status
    Sep 18, 2003
    374
    Austin, TX
    be careful dropping that stuff in the tank. I've done the crank case and sprayed in the carb (while running). I've also done a bottle in the tank, but I found that the chemtool loosened up the rust in the tank and what a mess that was. /forums/images/graemlins/crazy.gif Clogged the fuel filter and caused more problems then good.
  12. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I like Lucas fuel treatment. It works real good in FId vehicles. Dont know how it works in carbed rigs though. Everything I have is FId
    If your carb is old I suggust a new carb or a rebuild and a major tune up to improve performance/gas milage
  13. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    I usually dont use additives except for oil thickeners like LUCAS or MOTOR MEDIC in old smokey motors that guzzle oil--the best fuel system treatment we used to sell is CHEVRON TECHRON--it cleans better than all the other combined--but you can buy 6 gallons of gas with the same amount of money for a 12 oz.bottle of it--I'd make sure its really nessasary before spending the cash!.I get carbon out of the top end by pouring MARVEL MYSTERY OIL or plain old H2O down the carb very slowly,water doesnt smoke and it really works,turns to steam in the cylinders and lossens the carbon up--but its incompressible,so dont dump it in to fast--bad things will happen! /forums/images/graemlins/eek.gifWe have had real amazing results with the LUCAS products at my friends shop,their power steering and tranny treatment"fixed" a lot of customers tranny and power steering troubles,and the oil treatment quieted noisy valves on an Isuzu that even an adjustment didnt help--we were amazed that one of those "snake oils" actually worked very well! /forums/images/graemlins/grin.gif
  14. wild-will
    wild-will 1/2 ton status
    Aug 21, 2003
    185
    Oak town WA
    SO what youre sayin is to pour water into the carb while the engine is runnin?
  15. dyeager535
    26,979
    How are you figuring mileage first of all? These trucks drink gas in any case, but if you are trying to figure it off of the odometer, and you haven't made sure the speedometer is correct, your calculations are probably wrong.
    How about the basic tune up stuff? Plugs and wires will make a huge difference if they are bad.
  16. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    What you want to do is kinda dribble the water down the carb, NOT pour. Pouring would be BAD... Use a brick, block of wood, clamp, whatever... to get the engine turning about 1500rpm. VERY SLOWLY, dribble about a cup (I used half a Solo cup when I did it this way) of water down the carb/throttle body. Listen carefully to the motor; it will bog a little, that's OK. If it really starts to stumble and choke (hard to describe, but you'll know it if it happens) STOP POURING and let it recover. You don't want to drown the motor like this...
    I highly recommend an oil change after this procedure, to get rid of any water or carbon contamination in the oil.
    FWIW, I don't use water or ATF for this anymore, I use a product called "Sea Foam". I get it at my local NAPA, and the can has good directions for this use and others on it.
  17. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea my truck probobly could use it..it sounds a little o nthe weak side..feels weaker to latly..and i here a weird ticking near the headers like its arching foro a bad wire but ive just beed replacing wires that "seem" bad with other ones in the garage /forums/images/graemlins/rotfl.gif god im a cheap basterd /forums/images/graemlins/rotfl.gif should probobly pull the plugs and have a looksey so
