full circle clips for dana 60 ujoints
Discussion in 'The Garage' started by cegusman, Sep 16, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Do you just use the hardware store ones, or are there specific ones / what size do I need to find?
  2. gtina
    gtina Registered Member
    Nov 18, 2009
    6
    USA
    old thread i know, but i also need this information.
    thanks in advance guys! :bow:
  3. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Yukon sells them for a few bucks. I got mine from Randy's R&P. Hardware store might work as well if the proper dimensions.
  4. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    are they worth getting? i just bought a new pair of spicers and they have like the half clips that im about to install
  5. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    I'm not sure on where to buy them BUT you do need to do some work in order to use a full circle clip.
  6. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Like above you may have to clearance the shaft if running stockers. i ended up getting a set when I ordered my Factory 10 Chromo shafts. Even on a stock shaft I think they will do a better job of keeping the u-joints caps from popping out. Do not use the hardware store ones they are to thin and will allow slop in the caps. I think you can get them for $10 a set from randy's
  7. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,235
    284
    San Jose, California
    When I got my 60 shafts only the inner axles were already clearanced for full circle clips. I bought some full circle clips from ace hardware and they matched the clips that came with my axles. I did have to grind some of the stub shafts to allow the clips to fit like Scott said.
  8. Stomis
    Stomis Professional Amateur Premium Member
    Nov 20, 2007
    10,005
    230
    Roseland VA/PtPleasant NJ
    Full circle clips add a huge amount of strength to a stock style ujoint. In fact I believe the chars for a dana 44 shaft brought it from like 5500ftlbs of breaking force to like 6200lbs or something drastic for some dremel work and c clips.
  9. BGKYK5
    BGKYK5 3/4 ton status GMOTM Winner
    Nov 1, 2006
    5,936
    on the crapper...
    Anybody have pics of the material to be removed for the full circle snap rings to work? Or better yet a write up? I'd rather do it on a mill so you get a nice flat even surface for the snap ring. But your garden variety end mill isn't going to work. :thinking: I just don't know if I trust my dremel-fu on something like that.
  10. 84zz4ss
    84zz4ss 1/2 ton status Premium Member
    Dec 28, 2004
    1,342
    Pensacola FL
  11. BGKYK5
    Nov 1, 2006
    5,936
    on the crapper...
  12. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Just keep in mind you don't want any square edges (that will become a stress riser and will be where a crack will start and become the failure point).
  13. Stomis
    Nov 20, 2007
    10,005
    230
    Yeah you can also just lay a tack on each cap on the outside in addition to the half clip.
