full circle clips on ujoints
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by michaelm, Sep 24, 2001.
  1. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    i am changing wheel joints.
    anyone have an opinion whether filing the yokes to accept full circle snap rings is a good or poor idea.
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    I saw that done in a magazine article a while back...they claimed it helped prevent failure. It seems to be a subjective modification though. The theory behind it sounded good in the article if that helps...[​IMG]
    Rene
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I was told by a reputable drive shaft shop in AZ that full circle snap rings are not necessary. I was going to use them in my truck but he told me it was a waste of time.
  4. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    Well Moser and Warn have them on there Chrome-moly shafts so they must be there for a reason. I run the Warn shafts and aslo "fixed" my spare shafts to except the full external snap rings as well. Size= 1 3/16" external snap rings
    79 Blazer 6"lift 38 SX's locked/4:56 <a target="_blank" href=http://www.keith.rockcrawler.com>www.keith.rockcrawler.com</a>
  5. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Bad idea. Use a grinder instead, file will take forever. LOL
    Pat Gremillion ran one joint with one w/o snap ring for a while in his EB Dana 44. I think he broke the one side 2 or 3 times, but the side with the snap ring survived.
    He's running 60 front now though.
    Poundin' the ol "pavment"!
  6. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    I run warn axels with the normal clips the ends pop out of the caps befor the clips come off
  7. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Well, I modified mine with a Dremel tool and put in the full snap rings AFTER pushing out a c clip retainer and blowing a ujoint which in turn took out the axle ears of both stub and inner shaft.
    Its not a waste, it works.
    Depdog
    <font color=blue>Weenie K5, little mods' Small Tires!</font color=blue>
    <a target="_blank" href=http://depdogsk5.coloradok5.com>depdogsk5.coloradok5.com</a>
  8. donimator
    donimator 1/2 ton status
    Jun 11, 2001
    444
    Tacoma WA
    I did it. I thought it would work great. I went out wheelin, and I Broke the outer stub that I just modified. I think I weakens the part when you have to take off the metal to put the full circle ring in. I warn long shaft I have survived that ujoint explosion without a scratch.
    73 3/4 ton Chevy. 383 stroker, TH350, NP 205, 14bolt FF(Detroit), Dana 44(limited Slip), 6in. lift, 36x 14.5 super swampers
  9. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    My axles are "fixed" this way as well. Used a 4" grinder to remove the extra casting. Bigdaddyof2 did his as well.
    Mudzer 1978/91 K5
    <font color=blue><a target="_blank" href=http://www.mudzer.rockcrawler.com>www.mudzer.rockcrawler.com</a></font color=blue>
  10. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I lost 2 clips this weekend when I was out wheelin but the cups didnt come out.I noticed when inspecting my truck the day after I went.I think the full circle snaprings are a great idea.
    A balanced diet is a beer in both hands.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  11. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    What and where are you grinding to install full circle clips?
    And what kind of clips? Like the ones on the end of the caps on a driveshaft U-joint?
    <font color=green> Too bad ignorance isn't painful </font color=green>
  12. RedDwarf
    May 9, 2001
    816
    No, like the ones on the ends of your stub shafts. Full circle external snap rings.
    You have to grind around the back of the joint on the yoke. You grind it flush with the surface where the c-clips
  13. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
  14. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Warn and Moser run them just to be cool, at least when the axles are new. When everything is new it all fits together nice and you don't have problems, as they get stretched, you need the snaprings. This applies more to the factory shafts since the weaker material stretches more and loosens it's grip on the cap. BUT, I've got a buddy that ran the warns in a jeep with 37's and eventually the caps dropped in by hand.
    We have one customer that full circled a stock shaft and it go so bad that he was routinely breaking cups from having too much play in the yoke, but never lost a joint because he had the full rings.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  15. RedDwarf
    May 9, 2001
    816
    Robbie, the snap rings work with the regular u-joints.
    Stephen, what would be the point of not running the snap rings? In my experience, it gets really hard to remove the c-clips as they get older.
    Also, the customer you mention, d you mean to say that he never broke another joint after installing the snap rings?
  16. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    When I snapped the axle u-joint @ the Spring K5 Thing, it was evident that the c-clip had fallen out which allowed the cup to "walk" out of the axle flange. The damage occured when the cross shaft ripped through the side of the cup. I am confident that installing the snap rings (even on stock axle shafts) is not a waste of time.
    thebigdaddyof2
