Full Convert. door issues
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by atlantak-5er, Oct 22, 2003.
  1. atlantak-5er
    atlantak-5er 1/2 ton status
    Aug 20, 2003
    225
    Atlanta, GA
    I was running no doors for the last couple of months. So i bought some doors off of a fellow ck5er and they dont fit! Its not the doors though, it seems as if the windshild frame and firewall have sagged inward. I can push on the driver side of the windshield frame and it will move an inch or so. I was thinking about just welding the top of the windsheild frame to my roll cage to solve the problem. What do you think. Is this ok?
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    74
    Humboldt/Pacifica, CA
    It sounds like your rocker boxes are rotten, you might want to check them. Without these supports the firewall/windshield frame will sag inward, just like if you did a full convertible conversion on a halfcab. There are two ways to fix this. One is to rebuild the rocker boxes. The other is to connect the windshield frame to your rollbar, like you already suggested.
  3. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    sure sounds like your boxes are gone. on my 74 there is no play in the wind sheild frame. i wouldn't tie it into the cage with out fixing the problem of your saggy body first. with all that sag and then you take it wheeling and get really twisted up it could be bad news for thw wind sheild. thats my iMLAO /forums/images/graemlins/wink.gif
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    with all that sag....you take it wheeling and get really twisted up it could be bad news for the wind sheild.
    And the top!! /forums/images/graemlins/eek.gif. The P.O. cut out the subfloor (rocker boxes) in my '74 /forums/images/graemlins/angryfire.gif. I have broken the windsheild, top, and, both side windows multiple times /forums/images/graemlins/angryfire.gif You'da thought I would have learned after the first time huh?? /forums/images/graemlins/1zhelp.gif I am rebuilding the rocker boxes now out of 1" sq. tube and sheet steel. That should fix the body flex issue some.
    FIX THE ROCKER BOXES BEFORE YOU REGRET IT!!!!
  5. atlantak-5er
    Aug 20, 2003
    225
    Atlanta, GA
    How do you fix the rocker boxes? Do you just remove the fenders and go at it or does it require more dissassembly?
  6. atlantak-5er
    Aug 20, 2003
    225
    Atlanta, GA
    Or a better question. Where are the rocker boxes? Are they the boxes that are under the body under the seats?
  7. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Yes, those are it. The PO cut mine out /forums/images/graemlins/angryfire.gif I am basically fabricating mine from scratch. I am using 1" sq. tube and 16 ga. sheet steel. Because of the way they did it, I have to weld up a new frame using the sq. tubing, then cover that with the sheet steel. You may be able to get away with some reinforcment. For instance, you may be able to cut out the bottom of the box (don't worry, it's hollow in there), weld a frame up inside of it, and then re-weld the bottom back up. That might work. In my case, a total refab is necessary. /forums/images/graemlins/tongue.gif
  8. atlantak-5er
    Aug 20, 2003
    225
    Atlanta, GA
    So ican cut the bootom of the box to see the possible damage w/o making it worse?
  9. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Well, I won't say absolutely yes on that. Anytime you cut into anything, there is a chance you will cause some damage, or find out you were better off leaving it alone! /forums/images/graemlins/rotfl.gif For the most part though, they are hollow boxes. Once you cut the bottoms out of them (I'd only cut a section just big enough to see whats going on inside there, not the whole bottom) you should be able to see the extent of any floor damage. Also, since the bottoms are flat, you should be able to have new pieces of sheet steel cut to fit with a little over hang so when you weld it back up, you can get good pentration and keep the rocker box solid (IF the only damage is that the bottom of the rocker box is rusting out). I wish that were the case in mine! /forums/images/graemlins/1zhelp.gif
  10. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    If your rockers are bad cut them off and you will have access from the side.
