Full float 10 bolt?
Discussion in 'The Garage' started by PsychoticDeadGuy, May 13, 2005.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    I have heard of a full floater kit for the corp. 10 bolt but I cant remember the name of the company. Has anyone else heard of this? If so, could you tell me the place where I could find the kit?
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,081
    486
    Grand Rapids area
    I think Warn made the kit, but stopped offering it. I think you have to look for them used.
  3. dyeager535
    26,979
    IIRC floater kits for 10 and 12 bolts had a nasty habit of always leaking at the axle seal, which may be one of the reasons you don't hear much about them anymore.
    Besides the fact that for trucks, the kit probably cost more than getting a 14SF or FF, with little to none of the benefits of the larger axles.
  4. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Someone here in So Cal, K10andy or something like that has a FF 12 bolt for sale. It used to be under ORD's Green Blazer, Wally, and it works great.
  5. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    You could have a shaved, locked, and geared 14bff for the same price... why stick with 8.5" ring gears and 28 splines?
  6. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    IIRC the 10 bolt FF comes with new chromo 30 spline shafts. Still not as strong as a ff14b, but thought I would mention it for the sake of accuracy.
    j
  7. tuner-automotive
    tuner-automotive Registered Member
    May 7, 2005
    74
    oregon
    sorry to highjack but...............
    Het jekbrown , Im not a member yet so I cant PM ya but Im in need of a hard top w/sliders for my 90GMC Jimmy.
    Im in salem oregon and not far .
    I have a hardtop w/o sliders, wanna trade.
    Email me @ threelillys@msn.com
    Everyone else, carry on, LOL. :grin:
  8. dyeager535
    26,979
    Well, to play devils advocate to myself, a 10 bolt is much much lighter, and has much better ground clearance. (which is why I stuck with mine until it broke)
    All that said, in these trucks, *for the most part*, a beefier axle makes sense, especially if thinking about going FF.
  9. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    You can go 2 ways with a 10 bolt.
    First is a C-clip eliminator kit (Summit Racing). The problem with them is you need to buy 2 kits and spare axles. Put the second kit on the spares so everything is swapable.
    Or you can go with a rear disk brake conversion. the caliper will hold the axle in the housing if it breaks.
    Otherwise......14 bolt.
  10. PsychoticDeadGuy
    Jan 8, 2005
    753
    so disk brakes would allow me to get home if i broke an axle?
  11. zcarczar
    Feb 10, 2002
    2,495
    No, you would bend the caliper and caliper mount. I dont know why people say this, obviously they have never broken an axle because the axle slides out of the carrier and drops causing extremely bad camber, most likely bending the caliper mounts. While I havent tried it on my rear axle, I think there is enough movement in the caliper that would allow the axle to work its way out of the carrier.
  12. dyeager535
    26,979
    I agree. Once the axle isn't supported at the carrier end, (breaks in the middle for instance) you aren't going far without much more damage happening. It will tear the axle tube up, wallow out the end of the axle tube (had a 12 bolt that was ruined from a broken axle destroying the seal area) and probably force it's way out eventually.
    There was a post not that long ago where someones 14FF broke an axle, even without the tire working against it, the housing was destroyed IIRC. Much less likely in the 14FF, but in the case of the 10 bolt, the wheel is still attached to the axle no matter how you cut it, whereas the 14FF doesn't have that problem. You COULD pull the axle pieces out and keep going. (at least in FWD or locked in the rear)
  13. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Rear disc brakes on a semi-floating axle will usually let you limp off the trail if you break an axle shaft..........but it's not really practical to drive on the road this way unless you limp along for a very short distance.
    I've witnessed this happen on Jeeps with rear D35's a couple of times and the disc brakes have kept the the wheel assembly from walking out of the housing. They took it really easy and we were able to get them off the trail. I've never seen it break or bend the brackets, but I have seen it wear a groove in the caliper from the rotor wobbling around, which then needed replaced. The rear brakes are also affected because the wobbling rotor continuously pushes the caliper apart and therefore you might need to pump the brakes a few times when you apply it.
    Of course, I don't know why in the world anybody who goes wheelin' with a rear 10-bolt, D35, etc... would not carry a spare axle shaft (most of the guys I know who wheel regularly carry spares).
  14. MarcS
    Oct 4, 2002
    515
    NJ
    Uh, OK, what they said......My Bad..
