Full floater 10bolt VS. 14bolt swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84BIGBODY, Apr 13, 2000.
  1. 84BIGBODY
    84BIGBODY Registered Member
    Mar 15, 2000
    20
    TN
    Please! I'm in a bind. I need suggestions/advice as to wether or not to put the Warn full floater kit in my 10bolt. Or should i just go ahead and swap to a 14bolt. I'm running a 6in. lift with 36x12.50s. To put up with four wheeling anytime I get a chance which would be best.Any help is greatly appreciated!
  2. Truckfan2
    Truckfan2 1/2 ton status
    Apr 10, 2000
    343
    Northern IL
    go 14 bolt. the 10 bolt had it's main problems in the damn carriers... not so much the axle shafts. definenitly the 14 bolt man, all the way!
    NEVER been stuck... *yet*
  3. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    With 36's, I'd have to say 14-bolt. The general consensus around here seems to say 33's are as big as you want to go w/a 10-bolt and still wheel it semi-hard. Of course if you're a b@lls-to-the-walls offroader, the 14 is a no-brainer.
    [​IMG] Semper Maintenance!
    [​IMG] So many ideas, so little money...
  4. 84BIGBODY
    Mar 15, 2000
    20
    TN
    Thanks abunch!!!
  5. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    After talking with Stephen at ORD and Depdog, they both agree that a 12-bolt is plenty for 35" or so tires, depending on your right foot. Dep has been running a 12-bolt for a long time and loves it. The full float kit will definately beef what you got, but the carrier is still a little week. Going to a locker that will replace your carrier is a good upgrade. Personally, I'm torn. I've got the 14 sitting at my house, but I don't have the money to guy buy new wheels and tires and the stuff to convert my front to 8 lug. If cash is not a prob., and you got a little time, swaping over won't be a big deal. Just remember, unless you go with a semi float 14 w/ 6 lugs, your wheel and tire combo will need to be changed.
    Not much advice, just voicing my indecision too I guess.
    Kyle
    89K5
  6. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Keep this in mind, the 10 bolt ff kit is 700$...
  7. 84BIGBODY
    Mar 15, 2000
    20
    TN
    But you can find 15x10 8lug rims so that shouldn't be a big deal. I just hate to lose the ground clearance at the diff.
