Full floater 14 bolt in K20?
Discussion in 'The Garage' started by eldon519, Jun 7, 2002.
  1. eldon519
    eldon519 1/2 ton status
    May 27, 2002
    161
    Kennesaw, Georgia
    I ran across a K-20 truck today with what appeared to be a full floating 14-bolt in the rear. He said it hadn't been swapped in, it was just like that. I've never heard of this before, anyone know anything?
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    some 3/4 ton came with 14 bolt FF's
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    What year is the K20 you looked at?
  4. eldon519
    May 27, 2002
    161
    Kennesaw, Georgia
    I'm not sure about the year, i think it looked to be from the 70's, not sure. It also looked almost like it had a D60 front too but i'm not entirely sure, sometimes I get confused between the D60 and D44. It did have the 52" rear springs though so it wasn't a K-30 i don't think.
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    the best way to tell at a quick glance if it is a dana 60 it will only have 3 u-bolts 2 on the driver side and the passenger side will have 1 u-bolt and 2 studs /forums/images/icons/smile.gif dana 44's and 10bolts have 4 u-bolts /forums/images/icons/smile.gif
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    A LOT of 3/4 ton trucks came with 14 bolt ff axles. None came with Dana 60 fronts.
  7. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    yep i have one of these in my backyard right now.
  8. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    You can easily be fooled if your just looking at the big hub. A friend of mine had a 3/4 ton sub. with a factory 14 bff and what i always assued was a D60 but after looking close it was a D44 with the old external hubs wich are about as big as a D60
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    If the truck is the 70's years, between '73 to '80, then the 3/4 ton rear will be the 14FF. GM did not offer any other axle for these trucks. Even the '77 to '91 K30's used the same axle.
    D60's will have a kingpin knuckles which are identifiable by the 4 bolts holding the caps to the knuckles on the tops and bottoms of each side.
    3 u-bolts is another way to check.
