Full Floater : Semi Floater
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 81Bogger, Dec 16, 2001.
  1. 81Bogger
    81Bogger Registered Member
    Dec 2, 2001
    64
    Kalispell, Montana
    What is the difference between a Full floater and a Semi floater 14 bolt? As I understand it the FF is better, But I'm not sure why......is it true that in order to replace the rear brake drum (or pads) on a FF you have to pull the axel shafts??
    Thanks for any info.
    <font color=red>81</font color=red><font color=blue>Bogger<font color=blue>
    "<font color=blue>Mud under tire, and Fords in the rear view...<font color=blue>" [​IMG]
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    FF are easy to change axles. Pull the bolts on the hub and pull the axle out. The FF is stronger because the axles just transfer power, where as a SF axles hold the weight of the vehicle and transfers power. That and when you break an axle in a SF the axle comes out and leaves you stranded.
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    yep to do bakes on a FF you have to pull the shafts and the hub assy.
    Or convert to a disk setup.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The FF is also stronger since all the parts are larger. The SF has a 9.5" ring gear and 1.31" shafts, and the FF has a 10.5" ring gear and 1.5" shafts. They're two tottally different axles
  5. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    And the FF is 8 lug as where the SF is 6.
    <font color=green>[​IMG]1977 K5 GETTIN IT AWN[​IMG]</font color=green>
    BUILT NOT BOUGHT
  6. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    Paulie the SF comes in 8 lug as well.
  7. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    And you can pull the axle out without taking the wheel off on a 14ff. They don't have c clips so if you do brake an axle on one the wheel won't fall off.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  8. 81Bogger
    Dec 2, 2001
    64
    Kalispell, Montana
    Excellent. Thanks for all the info guys.......................
  9. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    my 14b SF is an eight lug. it's fine for now but once i break it i want like a dana 70 or 80. EVERYBODY and their mom has a 14bff and a d60, so when i upgrade, i'm gettin a dana 80, hopefully. is a dana70 stronger than my 14b sf?
    people that get good mileage aren't having any fun!
    scott,
    1989 GMC suburban 3/4t 4" lift rollin on 36" swampers, tbi350, th350, np241
  10. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    what do better burn outs sf or ff?
    hola
  11. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Probably the SF since its alot lighter, but if you start wheel hopping and break an axle, dont expect to drive home. The FF gives lets you get home if the axle breaks.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you have a locker or spool it will.
    Tim
  13. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    Only if you have a way of keeping the broken axle shaft from leaving the housing. You might be able to do drive it with a broken shaft if you have disc brakes but not likely with the stock drums.
    Scot in KC, MO
    Rough Country wont flex right? - <a target="_blank" href=http://coloradok5.com/gallery/albun29/aab>Pics</a>
    87 GMC 4" lift, 6 lug 14SF LockRite, 33s
  14. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
  15. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    Ya oughta do a little research before ya start telling folks that they are wrong. [​IMG]
    muddysub just posted that he has a 14SF 8 lug.
  16. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
  17. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have had (2) 14SF in 8 lugger flavor!
    Mike
    <font color=green>"1024x768x256... Sounds like one mean woman."</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  18. muddysub
    Jun 23, 2001
    10,451
    489
    so does anybody know anything about dana 80s?
    scott,
  19. Emmettology 101
    May 9, 2000
    8,126
    FL
    There is a Dana 80 Hybrid out there which consists of a Dana 80 center section and Dana 70 axle tubes and axleshafts.... They can be found in some Cummins powered Dodges....
    As like Forest says, " Thats all I have to say about that!"
    Mike
  20. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    From what I've seen, the 8-lug 14SF is very common. It was the standard axle found under 3/4 ton pickups and Suburbans starting sometime in the early to mid-80's and I think may still be used in the new Silverado trucks also. The 6-lug versions are fairly scarce since they seemed to only have been used in some light duty 3/4 tons and a few 1/2 tons (with various comibinations of towing package) starting in '88 when the new body style with IFS was introduced. It also seems as if they maybe stopped using the 6-lug 14SF in the 3/4 tons at some time as I haven't seen any trucks newer than maybe the mid 90's that were 3/4 tons with 6-lugs (though they could very well be out there).
