full floating 14 bolt *DELETED*
Discussion in 'The Garage' started by crazy427, Apr 1, 2004.
  1. crazy427
    crazy427 1/2 ton status
    Mar 10, 2003
    979
    Edison , NJ
    Post deleted by crazy427
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: full floating 14 bolt
    if it is out of a 1 ton you need to move the shock mounts and the spring pads.
    for ground clearence you can cut the bottom lip off up to the lowest bolt hole.
  3. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    Also will likely need a hybrid u-joint to get driveshaft hooked up. Neapco #21153 is Kragen/Shucks/Checker or Napa #447 are the part numbers for the 1310 to 1350 joint
  4. crazy427
    Mar 10, 2003
    979
    Edison , NJ
    ok, cool. Does anybody make adaptors so that i can still use my 6 lug wheels.Since they are only 2 months old /forums/images/graemlins/doah.gifand do i cut off the bottom bolt or just up 2 it.i dont have the rear yet i have only seen the truck from above and not underneth
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    ya TonyP makes some PM him I think $170usd
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I didn't get all the info when i started reading his first post, but are you saying that the 3/4 ton SRW and the 1 ton SRW 14bff's on the pick-ups are different?
  7. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    The 1310 to 1350 conversion u-joint is the Napa #348. /forums/images/graemlins/deal.gif
    But the correct conversion joint that he should need is the #447, unless his stock shaft uses the S44 joint. In that case, one of the guys with a Neapco book can chime in and list the right one. /forums/images/graemlins/waytogo.gif
  8. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    The axles (excluding the brakes) are the same. The difference is the shock tabs and spring perch locations. The 3/4 ton axles are a direct bolt-in for a 73-up 1/2 ton. They share the same 42.5" center to center spring perch spacing.
    The one-ton however, uses a spring perch spacing of 40.5".
    So, 55 willy is correct, if the 14BFF is coming out of a one-ton, the shock tabs and spring perches will need to be moved to bolt it into his K5. /forums/images/graemlins/waytogo.gif
  9. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Das coo, just double checkin, thanks for da info /forums/images/graemlins/thumb.gif
  10. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/waytogo.gif
  11. crazy427
    Mar 10, 2003
    979
    Edison , NJ
    Is the 14 bolt the same width as the 10 bolt?
  12. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Mine was, but it is also from the 3/4 ton.
  13. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    63-72 2wd 1/2 and 3/4 ton also have 42.5" pads, just that oen shock is mounted opposite way from 73-up
    the only 2wd before 73 that are not 4.25" pads are the Longhorns starting in late '68 and ending in 72
    tell napa what year and series the 14 bolt FF axle is from and what year and model your truck is that the axle is going under and they will hook you up with the right conversion U joint
    good luck
  14. crazy427
    Mar 10, 2003
    979
    Edison , NJ
    ok.... well i got the u-joint and i have the info on the wheel adaptors. just gotta find a locker or posi and 5.13s and ill be ready for the swap /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/waytogo.gif
  15. grd2go
    grd2go Registered Member
    Mar 28, 2004
    55
    Anchorage Ak
    My 14b ff out of a 91 crewcab bolted right in on my jimmy the only difference was the shocks I used the 205 out of the crewcab and part of the drivshaft too because there was a 4 in lift installed on the jimmy so the u-joints were no bigge the cheapest locker I found was a detroit try youre local gear shop mine takes good care of me because I also run a fleet of tow trucks witch means we buy alot of parts so they cut me good deals on my personal stuff... /forums/images/graemlins/crewcab.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    S44-1350 = Precision #447 or Neapco part number 2-1153 your choice /forums/images/graemlins/thumb.gif
  17. crazy427
    Mar 10, 2003
    979
    Edison , NJ
    so how do i know whick one i need /forums/images/graemlins/dunno.gif. I just purchased the 348 and it looks good but i wont now till i yank it out if its right /forums/images/graemlins/doah.gif
