Full Hydro Ram Mount w/Leaf springs
Discussion in 'The Garage' started by trollporter, Oct 3, 2006.
  1. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    Before anyone says it I've already searched but couldn't find exactly what I was lookin for. Here's what I've got. I just got a full Hydro kit from Rockstomper with the 8" double ended ram. I'm trying to figure out how I need to go about mounting this on a D60 with leaf springs. I was trying to figure out some type of hoop off of the axle but it would have to be either under or over the leaves and I'm woried that the leaves would hit the hoop when it flexes. Any pics of anyone who has done this or has any insight would be great. Preferably with 52" springs because they flex so much more (planning for future).
    thanks in advance, troy
    Oh yea, I forgot. I have high steer arms also if this helps.
  2. tlspeed
    tlspeed Registered Member
    Apr 20, 2005
    75
    Arkansaw, WI
    Hey, I mounted my double ended cylinder underneath my leaf springs in order to gain clearance from my oil pan. Only got 4" spring. I built a hoop out 1.5" square tube, came out at angles in front of diff. I mounted my cylinder to that. So far its been working great, no problems, occasiaonaly becomes a rock basher. If you send me your email i could send you a picture. In the future I plan on buildng a guard to protect the cylinder, and tying my the hoop in to the diff cover. tlspeed
    Oh, and i used high steer arms but mounted my tie rods underneath instead of on top
  3. trollporter
    Feb 29, 2004
    518
    Lady's Island, SC
  4. trollporter
    Feb 29, 2004
    518
    Lady's Island, SC
    BTT
    There has to be someone else out there that has some insight on the subject.
    troy
  5. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I'm interested too.
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I know Kert "Cyberfire" did his over the springs but I cant find any detailed pictures of it.
    Hopefully he will chime in.
  7. trollporter
    Feb 29, 2004
    518
    Lady's Island, SC
    I couldn't find a good pic of Kurts either. But if I remember from his post a few months back, he didn't use tube at all but instead built it out of plate steel and had the "Pirate Salute" in the center.
    The direction I'm kind of thinking in right now is that I should come off of the axle with a hoop under the springs that goes almost to each knuckle and have another riser hoop off of that in between the springs at the hieght that I need to mount the ram. Just need to be sure that I can still get the diff cover off.
    troy
  8. 54inches
    54inches 1/2 ton status
    Feb 9, 2004
    1,535
    Houston, Texas
    Fourwheeler did a writeup about it in the newest issue.
  9. trollporter
    Feb 29, 2004
    518
    Lady's Island, SC
    10-4. I'll try to track it down.
    troy
  10. Black Ice Fab
    Black Ice Fab Newbie
    Oct 5, 2006
    golden
  11. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
  12. trollporter
    Feb 29, 2004
    518
    Lady's Island, SC
    Thanks man! thats pretty much what I'm thinking exept I need to run another hoop off the top of that to line the ram up with the high steer arms.
    thanks, troy
  13. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    I can't see the pics either. I'm really curious on how you guys have done yours.
  14. Black Ice Fab
    Oct 5, 2006
    golden
    [​IMG][​IMG]we tried it in internet explorer and it the links work fine fire fox doesnt seem to work to well with ck5[​IMG]
    let us know if you cant se these pics!!
  15. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    I can see them now. You've got a nice setup there, very clean. Who's ram and orbital are you using. what sizes?
  16. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Looks good, but would like to put mine up over the springs out of the way.
  17. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    looks good and clean! hope your planning on swappin out the 10bolt front. how do you like that steering setup
  18. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Ours is all done with plate steel. 3/8" thick legs, 7 ga. across the front and a .25" plate across the top. 3/8" thick key stock cylinder blocks and then tied to the diff cover bolts with a 1/4" thick ring. The ring is removable via the 2 half inch bolts in between the mount itself and the diff cover.
  19. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    kert, i love the middle finger jesture in the hydro mount. very creative!
  20. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Kert, what kind of arms are you running that your tie rods have enough clearance??
    I see you have a zero rate AND a overload in the pack.
    I have just a zero rate with a 4 leaf pack and it is prolly still 1/2"-1" to high.
    I was running a Sky mfg. arm which I thought was the tallest on the market.
