Full hydro steering........with hydroboost brakes
Discussion in 'Center Of Gravity' started by 6.2Blazer, Oct 18, 2004.
  1. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,648
    8
    Ohio
    I was getting ready to update my steering from the stock setup to crossover and started to think about just going full hydro. I like the idea of crossover with the ram assist, but I can't afford to do both at this time.......though I don't know what full hydro by itself will cost either. Just starting to get some full hydro research going.......
    My biggest concern with either hydro assist or full hydro is that I have hydroboost brakes (it's a diesel, if you haven't guessed....) and have heard of people having issues with hydro assist and the brakes.
    This will be for my '90 K5 that's pretty much a trailer queen. It just needs to be able to travel a few miles on public roads to get between the trailer parking lot and the trail.
    This last weekend I talked to a couple of Jeep buggy guys out on the trail who just got orbital valves off of combines or whatever in the junkyard and said they worked good??? I've always heard the system needs matched, and I also want some steering control if the hydraulic system fails (I've read this is possible......basically like loosing power assist on normal steering).
    So, anybody running full hyrdro??? Any issues?? How did you do it??
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I run two pumps. A bone stock pump for the hydroboost and a KRC racing pump for the steering. It puts out 4gpm and 1800psi.
    As far as an orbital heres what you need. You need to first pick your steering ram. Double ended balanced ram would be the best choice, or two single ended rams. If you run a single single ended ram you will end up with a different number of turns lock to lock from one way to another.
    You need an Open Center Load Reacting orbital. You do not want Load Sensing. Load reacting means that when something hits the tires you will feel it in the steering wheel much like manual steering. This will also cause the return to center when coming around a corner which you will not have with a non-load reacting valve. Most tractor valves are non-load reacting.
    And last, you need to calculate the volume of your ram. Say your ram is 22 cubic inches. This means it will take 22 cubic inches of hydraulic fluid to move the ram from one side to another. You need to figure out how many turns lock to lock you want in your steering wheel. Most want around 3-4. Say you want 3. Divide 22 by 3 and you get 7.33. This means you need an orbital valve that displaces 7.33 cubic inches of fluid per revolution.
    I'm getting my valve from the local hydro shop. It's a danfoss unit that fits my needs perfectly.
  3. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    When choosing a pump(if you go bigger or modify your pump) try and keep the pressure down. A hydro boost system doesnt like as high a pressure compared to regular steering system(non hydro boost) If you go to dual pumps you won't have to worry about it.
    On my full hydraulic system with hydro boost I used an AGR pump that come with my rock ram. It seems to work pretty good so far. I would not go out and buy another one though, I replaced mine twice within a couple months and I have heard alot of other bad stories about them. I think if you just modified your stock pump it would work good enough.
    Sean Stapely(STATION on the Pirate4x4 board) sells a high output pump(like 6.5gpm) that has 2 high pressure outs for like $160. Thats what I plan on doing when I go to the rear steer. Thats about what you would pay for and AGR pump. /forums/images/graemlins/truck.gif
  4. RestForYourSouls
    RestForYourSouls Registered Member
    Aug 22, 2006
    7
    Virginia
    I know this post is old as dirt but I wanted to know if you made any progress with going full hydro on your 6.2 blazer?
    I have a 6.2 rig as well and wanted to go full hydro.
    What's your setup and what did it end up costing you in the end?
  5. 6.2Blazer
    Feb 24, 2000
    4,648
    8
    Ohio
    I haven't looked at this page for years, so ironic I glance at it today and find your post.
    Never went full-hydro but did go hydro-assist a couple years ago. The only problem I had was getting the p/s belt to quit slipping. Wound up using two belts and since the belt slipping issue has been resolved it works great. 1.5" ram, pump modified for slightly more volume and pressure.
  6. ktmoutfront
    ktmoutfront Stuck going nowhere fast Premium Member GMOTM Winner
    Feb 20, 2007
    10,083
    586
    Would rather be on the road
  7. Litho
    Litho Registered Member Premium Member
    Sep 21, 2009
    14
    Blaine, wa
    What advantage do you see in using full hydro assist? Are you just looking to eliminate your vacuum pump?
  8. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    I asked this same question on Pirates and was told by many there will be no problem.I have the stock hydroboost pump from a 1ton truck and added the ram assist and box from a 93 chevy.Just got the lines modified the other day.But have yet to put them on and see how it works.Maybe this weekend.
  9. sfhdweb
    sfhdweb Newbie
    Feb 21, 2011
    chicago
  10. offroadman83
    offroadman83 Registered Member
    Feb 10, 2006
    24
    Edinburg, Texas
    Any more updates on this?? About to do all the plumbing on my double ended ram with hydroboost brakes and been looking for more insight on it and some more successful stories and especially photos of doing so. Thanks-----------Kyle
  11. GreenieK30
    GreenieK30 1/2 ton status
    Jan 23, 2010
    664
    Washington
    My truck is a 1985ish K30. It has factory hydroboost. It was leaking so I replaced it with a Vanco unit, they also modified it for full hydro steering. I ditched the stock steering and went with a Howe single ended ram kit. They work very well together. With 54" Boggers or 47" LTBs it steers and stops better then a stock truck.
