full size spares
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ChevBlazin, Apr 26, 2002.
  1. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    Does every one run a full size spare? I have 35" mud terrains and a worn out 35" kelly mud tire as a spare. Problem is it wont fit on the stock spare tire carrier between the rear seat and tailgate (almost does) Right now it is flat on the rear floor, but would like to mount it upright between the rear seat and tailgate. Its so close that a 33" spare would solve the problem. since I run open differentals would a 33" spare be all that bad? The way it is I only run my current spare on the front with hubs unlocked if I need to use it.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you don't have a traction device of some kind, then yes, you can run a smaller spare tire. I wouldn't recommend it, but you can do it. If you already have a 35" spare, then I say just keep it.
    If you have a traction device, don't run two different size tires on that axle, and if you have traction devices front and rear, don't run differnt size tires at all. You will wear out the traction devices, or possibly break them.
  3. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    If you have onboard, let the air out of the spare. That should allow you to mount it in the factory position.
  4. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Get the lmc truck (www.lmctruck.com) catalog and buy the '73-74 spare tire bracket, or find it in a junkyard(good luck!).
    The '73 and '74's had the spare tire mounted upright, parallel with the rear seat, right behind it on the left side of the cargo area(instead of upright, parallel with the bodyside on the rightside). All I had to do to mount a 35" tire there was drill a slightly larger mounting hole and it fit perfectly.
    BlazerMan
