full time 4wd question np203 transfer case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by nwk5blazer, Jun 13, 2002.
  1. nwk5blazer
    nwk5blazer Newbie
    Jun 13, 2002
    Wenatchee Washington
    i have a 75 blazer and its got the crappy full time 4wd on it still, i removed my front drive line and it won't go into gear when i have the transfer case in 2hi or 2lo, only 4hi or 4lo.....any ideaS?
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I don't know why it works that way, it just does. I have the same thin gin my '74. I had to work on my front drive shaft and I had to lock it into 4 HI before it would move. If I didn't, it would make all kinds of bad noises /forums/images/icons/tongue.gif . I ran it that way for a week. It didn't seem to hurt it, but I wouldn't make a habit of it. I am waiting till I can afford a 205 so I can do the doubler /forums/images/icons/smile.gif .
  3. ratpack7
    ratpack7 Guest
    It's because there isn't a 2hi-lo on a 203 just 4lo/loc 4lo N 4hi 4hi/loc. in 4hi or 4lo there is a differential action that transfers power to which ever axle needs more. In 4lo/loc or 4hi/loc it splits the power evenly between axles. Which means that in 4hi or 4lo your T-case thinks that the front axle is spining and sends all the power up front. So pull the stick in to 4hi/loc ( all the way back twoard the seats ) and you'll be fine. I'm running mine that way with the manual hubs ( add on ) unlocked and it runs fine.I hope this has answerd you question. /forums/images/icons/smile.gif and I agree on the doubler so save that T-case if your thinking of geting a 205.
  4. nwk5blazer
    nwk5blazer Newbie
    Jun 13, 2002
    whats this doubler thing you're talking about?
  5. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    Is there an article on installing a NP203 doubler with a 205? I'm sure there must be some text on this. Any ideas?
  6. tacoma972
    tacoma972 1/2 ton status
    Jan 6, 2002
    114
    West Point, Ga.
    CHECK WITH BILLY RAY ON THE DOUBLER. HE JUST FINISHED IT UP.
    HIS WEB PAGE IS www.baloo.rockcrawler.com
    HE HAS PICS AND ALL THAT STUFF
  7. ratpack7
    ratpack7 Guest
  8. Grim-Reaper
    7,385
    Atlanta
    Ever try the search button? This is a weekely subject. Should be about 1000 posts on this.
    Transfer cas has a diff in it. missing a drive shaft it won't go in anything but loc. Sounds like it works just fine.
    It's only the second strongest case ever offered in these trucks. must be junk because you don't understand how it works.
    Both of mine work great with over 300k on each.
    Welcome to CK5 /forums/images/icons/smile.gif
