Full time 4x4 can a 33 work as a spare????
Discussion in 'The Garage' started by ntx78k5, Jul 20, 2005.
  1. ntx78k5
    ntx78k5 1/2 ton status
    Oct 22, 2004
    166
    Home of the Rangers
    I have a 78 with the full time 4x4 I can never remember what TCase that is but I am running 35's with a 4" lift. I carry an old 33" spare as that is all that will fit inside in the normal carrier.
    My question is can I even use that 33 if I get a flat without screwing up something in the drive train?
    Eventually I mount a spare tire carrier on the back bumper that will hold a 35 but until then it it even worth my time carrying that 33 around?
    Thanks,
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    NP203
    I would run a 33 for a spare, it's better than nothing. Don't put your t-case in the "LOC" position though.
  3. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Yep, what he said. You'll be fine as longs as you don't have your axles locked or spooled. I carried a 33 as spare for awhile and used it a few times while runnig 36's.
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    it wont matter if the tcase in in lock, the only think that matters is if he has some sort of locker
  5. ntx78k5
    Oct 22, 2004
    166
    Home of the Rangers
    All good news, and thanks for the info. I just run it in normal 4 wheel. In fact I've only moved it to 4 wheel lock once and that wasnt even 4 low.
  6. divorced
    Jul 20, 2004
    5,115
    The t-case could be considered a front-to-rear locker, and with a smaller tire on one corner of the truck it will make the driveshaft for that axle spin at a different speed than the axle with the same size tires. The difference in size isn't very much though so maybe it wouldn't have any serious negative effects.
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    hummmm ya i guess that makes sence, it would make the driveshaft spin a little faster/slower. that would not be good
  8. 4trolls
    4trolls 1/2 ton status
    Nov 13, 2002
    190
    vancouver wa
    not to sound like a dumb ass but ,with a locker couldnt you let the air out of the 35 until its 33" tall? :confused:
  9. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    I wouldnt want to drive anywhere at any real speed with a tire aired down. I live in Hollister, maybe 8 miles from "Hollister Hills" SVRA, and I wouldnt want to do the few miles of 55+ MPH with a tire aired down to be same height as another. And how would you do it? Eyeball from one side of truck to the other?? :confused:
  10. 4trolls
    Nov 13, 2002
    190
    vancouver wa
    the spare is not on the truck so you could put it right next to it, and close enough should be good enough for a spare.....I would think
  11. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Maybe I'm way off base here but my common sense meter tells me that even if you aired down a 35 to the height of a 33, it would still have a larger circumference due to the fact that the tire is simply bigger...that being said, yes, a 33 will work fine for a spare in a pinch.
  12. Scrubby
    Scrubby 1/2 ton status
    Dec 1, 2001
    114
    Boise, ID
    Even if the case is in LOC, won't the open differential handle that one wheel spinning faster and not affect the drive shaft speed? That's what differentials do. They allow one tire to spin faster than the other.
  13. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    The open diff would make up for half of the difference, not all of it.
    I've driven 15 miles at 55+MPH on 5 PSI in 36" radials, would do it any day. Sometimes that's just where the nearest gas station is.
  14. divorced
    Jul 20, 2004
    5,115
    Think of it like running 31's in the front, and 44's in the rear - only not as drastic. The differential in the axle will balance the difference from left to right, but not front to rear.
  15. Scrubby
    Dec 1, 2001
    114
    Boise, ID
    Ahh. I see now what you mean. The diff will equalize the axle, but that still might be a different speed from the other axle.
  16. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    If I had a locker I would go with same size tire. I wouldnt want to have to worry about the bad things that can happen with an under inflated tire at highway speeds. Generates heat and then possible tire failure. If the axle isnt locked I would have no problem using a 33" tire as a spare. As long as the other tire isnt bigger than 37".
    Oh and about having the tire off the truck to check size with the tire on the truck...with the truck weight the tire could loose an inch of height. But hey, you do what you want and I will do what I want and we will both be happy,
