Full time front axle convert to part time
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fourwheelinj1, Jun 7, 2003.
  1. fourwheelinj1
    fourwheelinj1 Registered Member
    Sep 18, 2002
    18
    Wake Forest North Carolina,USA
    I have been looking for a set of 3/4 ton axles for a long time now and i have finally found set from a 77 3/4 ton but the front axle is a full time dana 44. How easy is it to convert this type of axle to manual hubs. I thought i read something about having to have the axle machined to fit the snap ring of the manual hubs and that sounds expensive. What are the part numbers for the warn premium hubs to fit this axle and the superwinch ones? Also i see people talking about flat and closed knuckles and i don't know what that is. Will the dana 44 have the right knuckles to bolt right in to my 85 blazer? Thanks for any help.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I think you just need the manual hubs, and the spindle nut coversion kit. Shouldn't be to hard. I think the kit is around $25.
    -Brian
  3. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    I's get a set of narrower tires before trying anything else
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    What the heck is up with your idiotic tire responses?
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah you just need manual locking hubs off a part time axle, but without converting the 203 case to part time internalyl you are just unlocking the shafts from the hubs and on 203 trrucks the shafts always are powered at all times, so youll still be turning shafts but at least will be able to unlock the hubs from them, but keep in mind that in hi or lo without loc the case differentiates front to rear dpedning on which axle has traction, until you put it on one of the two loc ranges, then both axles get the power to them no matter what
    cant help with the tires thing ?? /forums/images/graemlins/ignore.gif
    good luck
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    But he is putting it into an '85. That would have an NP208-ie already part-time.
