Full-time *gear-driven* t-case?
Discussion in 'The Garage' started by speedup, Apr 4, 2003.
  1. speedup
    speedup Registered Member
    Aug 1, 2002
    58
    Rhododendron, Oregon
    Just curious, but does such thing as a full-time gear-driven transfer case exist? I love my full-time NP203, but that chain stretch thing just gets annoying... /forums/images/graemlins/frown.gif Or, better yet, has anybody ever replaced the chain in a 203 with a series of gears? Maybe somebody makes a super-strong chain that is impervious to stretching <rubs rabbit's foot vigorously>? All I ever want in this world is a bullet-proof full-time t-case that can handle massive torque, is that so much to ask? /forums/images/graemlins/smile.gif
  2. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    How much torque are you talking about? The 203 is stronger than most people give it credit for. As long as the bearings and chain are good I wouldn't worry about it. How do you know that the chain is stretched? I have had the same chain in mine every since I bought it in 90 so mines over 13 years old.
  3. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    The only upgrade I know of is if you have the 2" wide chain you can get new 2 1/2" sprockets and chain that will take a little more abuse.
    If you keep burning up chains, why not just put a conversion kit in it and forget about it?
  4. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    ... that conversion kit only makes it a part time case from a full time case...it does not eliminate the chain.
  5. Grim-Reaper
    7,385
    Atlanta
    Those chains will run 100k no problem. If your tire wear on all four tires is not even then it puts more stress on the chain. That right there is where 90% of the 203 bad rap comes from is people not replacing four tires at one time and keeping them rotated.
    There are cheap chains out that do not hold up as well as others. I'm running a Mile Marker chain and it seems fine after a couple years of abuse with double lockers and a year of 35's.
    Mile marker also sells a chain tensioner called a chain saver. www.milemarker.com
    What it does is put the front outout on excentrics so you can tighten it up some.
  6. Goober
    Apr 26, 2002
    2,222
    Yes, I realize that. I've installed both types (and even welded gears) in many trucks.
    The benefit comes from the fact that when the transfer case is not locked the chain isn't turning the front shaft.
    If you don't use it, you can't break it and it won't wear out as fast.
    /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if you want a full-time gear driven t-case why not just get a np205 and always run it in 4hi?
  8. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I'm assuming he doesn't because of the driveline bind on the street.
  9. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    install a np205 and never take it out of 4hi/4low.
    j
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Because you can't drive it on dry pavement in 4WD. 203's have a differential inside the case that allows the front and rear driveshafts to rotate and different speeds. Without the diff in there, the truck will feel like someone is pushing the brake pedal when you turn a corner, due to massive driveline windup. /forums/images/graemlins/eek.gif
  11. MontanaLifted
    MontanaLifted 1/2 ton status
    Aug 27, 2002
    171
    Sounds like one of the first questions is why does it have to be "full-time"???
    Part time will save on parts and gas.
    I have a np203 in my rig and I hate it. After my new engine next month my next purchase is the part time kit.
  12. speedup
    Aug 1, 2002
    58
    The chain on my 203 pops when I apply more than ~70% throttle, so I assume /forums/images/graemlins/shocked.gif it is stretched. It's not the u-joints or drivelines and it gets worse in 4-lo.
    As for why it has to be full-time, I just like it that way. /forums/images/graemlins/smile.gif The wear-and-tear and poor gas mileage does suck, but I like the handling characteristics of full-time
    (it has saved my tail many times).
    Either way, my ultimate goal for my Blazer is a built big-block. How much torque can a 203 stand up to? Maybe I've underestimated the t-case?
  13. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    my run-a-205-fulltime comment was a joke. /forums/images/graemlins/smile.gif I have to agree with the other guy tho... why would anyone want fulltime? thats for subarus and stuff...
    j
  14. speedup
    Aug 1, 2002
    58
    heheh... You've got a point, but you can have my full-time case when you pry it from my cold, dead truck. /forums/images/graemlins/tongue.gif
  15. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    <holds up beer> ... heres to your rigs loooong life. /forums/images/graemlins/grin.gif
    j
