full time t-case question..
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shane74, May 1, 2002.
  1. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I replaced all my drive shaft u-joints a couple of months ago. Yes, front and rears were replaced. Now, I am hearing a noise that sounds exactly like a u-joint going bad. It is coming from the front drive shaft at what sounds like the #1 or 2 u-joint up at the t-case. I greased them all up, and the noise was still there. So I pulled the drive shaft out, locked in the t-case (pesky irritation of a full time t-case) so I could drive it, and the noise disappeared. I have been running it for a few days like that (since Sunday afternoon). I am replacing them tonight, but my question is, could I have damaged my t-case? It doesn't make any funny noises or shift hard, but is running it like that for short durations ok? I drive about 10 miles on the freeway to work and back, other than that, the rest has been local neighborhood stuff, nothing over 40 mph.
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I don't think you've caused any damage. Driving it in Loc simply locks the differential inside the transfer case.
  3. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    I had the same noise on mine. What I found was that the ball and socket connector betweeen the CV joint had been pulled apart. There was about 1.5" of play when I had it off and in my hands. In makes a noise like the transfer case chain is over streched and rubbing on the insides of the case.
    Try a junk yard for a good one and see if you can get the part new at a driveshaft shop or something.
    I haven't replaced mine yet because I will need new shafts when I get a bigger lift.
    I hope this helps and makes a little sense.
  4. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Thanks. I replaced to u-joint last night and the noise is gone, but I think my driveline needs to be rebuilt. I could almost press the caps into the yokes by hand. The old ones came out w/out much effort, but then again, they were only 3 mos. old. Not too much time to get a lot of gunk to stick to.
  5. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    that's what happened to mine too. that ball in the middle of the cv just scattered.
  6. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Well, I now am carrying a 1/2" end wrench in the truck just in case it goes gonzo on me. At least that way I can pull over and yank it out in an emergency.
