FullFloater front axle, wide 16.5 rims???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by uglytruk, Mar 29, 2006.
  1. uglytruk
    uglytruk 1/2 ton status
    Oct 24, 2004
    1,329
    IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
    Among the junk I've collected, is a front axle off a '77 3/4T Sub. It has floating front axles. I guess if I put these on another truck, I'd install manual hubs. What can I learn about this axle?
    Next are the wheels from my '79 3/4T 2wd. They're 16.5 and WIDE! Why are all the 16" rims, even to current, so skinny, compared to the 15" Rallye Wheels?
    The manual hub is on a rusty '85 1/2T I saw in a field. Not the usual variation...
  2. uglytruk
    Oct 24, 2004
    1,329
    Now the rims...
    The pumpkin (above) is from the same FullFloater
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    That first pic is a 3/4ton D44 external hubbed front axle
  4. uglytruk
    Oct 24, 2004
    1,329
    Whatza D44? Sumptin' Clint Eastwood would carry? Is Advance gonna' have da partz? Manual hubs? Whatz the last year? Larger JB7 calipers like my '87 3/4T w/HD (13") rear brakes?
  5. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    dana 44. 8.5 inch ring gear.
    last year for dana 44 was 79 or so.
    advance should have the parts, or can get the parts if you know what you are looking for and can find a counterperson worth a crap.
    dunno on the brakes.
  6. uglytruk
    Oct 24, 2004
    1,329
    Weird? Saw on I89 (South), Burlington, Vt...Ct tags...
    Dually fenders, but not a dually... Any clue?
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Dually axle running a single wide wheel
  8. uglytruk
    Oct 24, 2004
    1,329
    The Dana 44 looks like the fr axle on my '83, and '87... just coincidence? I'll check www.warn.com for man hubs... But I like the jumbo knob on the above picture. I'll try and buy the hulk. I have a similar set elsewhere from SEARS, I think... Easy grip, good w/gloves! :eek1:
  9. uglytruk
    Oct 24, 2004
    1,329
    Will these fit the Dana 44?
    SUPERWINCH Dana 44 Manual Locking Hubs Part 400518
    [​IMG][​IMG][​IMG]You are signed in
    [​IMG][​IMG][​IMG][​IMG][​IMG]
  10. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Those are internal hubs, that one takes external hubs
    External hubs actually have a spacer between the hub turn dial knob and the bearing hub on the spindle
  11. uglytruk
    Oct 24, 2004
    1,329
    Yeah... Plasticy corrogated spacer thingy. Leaves the hub out in the breeze, though. I'll try AZ and hold one in my hand...
  12. uglytruk
    Oct 24, 2004
    1,329
  13. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    thats the right hub for the 8 lug d44 in the first picture.
    if you run one of these, check & tighten the 6 3/8" bolts EVERYTIME YOU PUT IT IN 4 WHEEL DRIVE! They back out like nobodies business, loctite, lock washers, nothing has kept mine in, so i just tighten them every time.
  14. CrewCab59
    CrewCab59 1/2 ton status
    Aug 13, 2005
    483
    Knoxville ,TN
    Those are not dually fenders,they are made to look like dually's.They make a kit for the burbans,put dually wheels on a single axle with these fenders.
    Also the wheel's that you have the 16.5's are 8'' wide ,16's are 6.5 .most of the 8'' wide came on camper special trucks
    CrewCab59
  15. uglytruk
    Oct 24, 2004
    1,329
    MileMarker 423 hubs for my '77 3/4t Dana 44?
    Right on! the deep-dish wheels came with my CamperSpecial '79 3/4t. Learn something new everyday! :wink1:
    Next question... MileMarker 423 hubs. Are they the ones that will fit my floater fr axle? Partz 4 sale are 19 spline. Says to '77 and have plasticy spacer. Just want to make sure...
  16. uglytruk
    Oct 24, 2004
    1,329
    More hub questions...
    Are MileMarker (StreetMaster) 302 the same as 103? The listing says 1/2 PU, then Jimmy/ Sub. I just took Warn hubs off my '86 1/2T 'Burb and popped 'em on my '87 3/4T 'Burb. And they sure look like my '83 1/2T PU...
  17. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Kinda off topic, but all front axles are full floaters. I am assuming you are calling this one a floater becuase of the hub. Full floating simply means the weight of the vehicle rides on the bearings on a spindle. Semi floating axleshafts support the weight on the shafts themselves 10b 12b and the 9.5" 14B. Just thought I would clear that up for ya.:D
  18. uglytruk
    Oct 24, 2004
    1,329
    Yeah, need some lessons... 1:15 AM now, so tomorrow... Thanks, Andrew
