fullsize axles on an s-15
Discussion in 'The Garage' started by Dain Fraser, Apr 13, 2006.
  1. Dain Fraser
    Dain Fraser Registered Member
    Jun 30, 2005
    32
    Canada
    I am thinking about buying an s-15 with a 350, hyrdamatic 700 tranny, and a 9 inch lift in it. I would like to take the 12/10 bolts out from under my k-5 and swap them into the s-15. I assume the spring perches will have to be moved inwards, but, my question is for a begginning welder like myself is it worth it to try moving the perches myself or should I have it done professionally. Is there anything I'm overlooking? Any tips for how to run the brakes etc?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you will have a lot of axle stick out becasue full size axles are a lot wider
  3. Dain Fraser
    Jun 30, 2005
    32
    Canada
