Fullsize spare or not?
Discussion in 'The Garage' started by 88K5Jimmy, Jul 12, 2003.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    I am currently running 36" PJ's. Can I have a 35" tire as my spare or does it have to be a 36"? I was talking to the local tire store guys and they said that I couldn't even run a 35" tire because there would be different amounts of revolutions between the two sizes. I can understand what he is talking about, but is 1-2" of tire size really that big of a concern?
    The only concern I have is having a flat on the highway and having to drive it a good distance to get it fixed.
    Ross
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    If your diffs are open that can work on a temporary basis.
  3. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    if u have a detroit yur jus gonna love it. of course if its in a 14bff u can just remove one shaft (if u have a detroit and a cap to keep fluid from dumpin out the end) and drive home that way.
  4. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Or if you do get a rear flat, you could just take a front tire, put it on the back, take the spare and put it on the front.
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Im a believer in running a same size spare.Ive cut 2 sidewalls in 2 weeks,both on the first day of 3 and 4 day trips.It would be annoying to wheel for any legnth of time offroad with one different size tire.Iv heard PJs run closer to the size listed on the side wall and Iv seen that most 35s made run small,like under 34".That dont sound like a fun ride /forums/images/graemlins/grin.gif Any spare is better than nothing to git you home or off the trail /forums/images/graemlins/thumb.gif
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if you are locked then yes you have to have the same size spare if your difs are open you can have a smaller spare /forums/images/graemlins/thumb.gif
  7. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Yeah I measure my PJ's and they do measure a true 36" tire, actually, just a lil bit taller. I was thinking a 36x12.5x15 TSL radial, because they appear to be a narrower tire for being 12.5" wide and I would be putting it on a 8" rim. Trying to keep the weight down also. However my dad has these tires and they only measure about 35", maybe smaller if I find a used one like I'm hoping. Ohh and I have open difs.
  8. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Trying to keep the weight down also.....
    HAHAHAHAHAHA!!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/eek.gif
    That's a funny one... Seriously, what do you think you will save weightwise between a 35" and a 36"? I'll bet your truck is already at 5500Lbs, saving 10 Lbs at this point isn't going to mean much.
    My vote is to suck it up, and buy a matching spare...if you actually DO get a flat, you are going to be a lot happier having a CORRECT tire to swap on there. /forums/images/graemlins/thumb.gif
  9. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Well originally I was just going to keep the 31" and limp to the nearest place to get the 36" fixed, but then I thought about the posible road-trips I might drive on and that started to seem like a bad idea. So originally I was trying to keep the weight down by keeping the 31" tire instead of getting a fullsize spare.
