Fulltime 4wD to part time??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90blzr, Apr 14, 2001.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    What is involved in changing out a Dana 44 from full time to part time 4wd?
  2. 84K5WITHAJUNK305
    84K5WITHAJUNK305 Registered Member
    Feb 25, 2001
    41
    Denison TX
    I assume by your username that your blazer is a 90. The first thing I'd do it find out what transfer case it's got, then I'd find out if anyone makes a part time conversion kit for it. Sometime in the late 70's GM started using it's own front axle, which is the 10 bolt, not a Dana 44. If you've got a 44 that you're going to swap in, just buy a set of of manual locking hubs and you should be good to go.
    A broken 84 k5 and lots of mud, it sucks to be me
  3. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    Sorry, I should of explained myself a little better. Yes I am swaping in a Dana 44 in place of my 10bolt (lug pattern). So all I need to do is buy a set of manual locking hubs and put them on, sound easy enough, thanks.
